fuse links - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 2nd, 06, 04:54 PM Thread Starter
fuse links
How do I check to see if a fuse link is bad? I tried the continuity, but that won't tell me if a wire is weak and it will show continuity even if one small wire is still conected in the wax coating and my OHM meter is not saying anything. Is there another way to see if it chaecks out good?
shadowhawk2878 is offline
post #2 of 4 (permalink) Old Oct 2nd, 06, 04:58 PM
Re: fuse links
When i needed one years ago, they were not available. in my opinion, i would just replace it, spacially if it old. when it comes to the wire, i replaced that main one as well. hope this helps.
1968 Camaro
2010 Camaro
Cabrera is offline
post #3 of 4 (permalink) Old Oct 2nd, 06, 04:59 PM
madmax87's Avatar
Re: fuse links
Are you saying your ohm meter is reading an open? A 1 onthe readout. Go to the lowest setting. Usually 200 and see what it reads. Move the wire around while reading and see if it changes. What makes you think the link is weak?
madmax87 is offline
post #4 of 4 (permalink) Old Oct 2nd, 06, 05:07 PM
Re: fuse links
other than a visual and mechanical check, there is really no way to test them.
They can be replaced, madelectrical.com has them, but they don't look exactly like the originals.
I'd say if they get hot while loaded that might also be a sign of weakness
fuse help 400bird Electrical & Wiring 4 Jan 31st, 06 02:29 PM
Courtesy Fuse blowing Rich Washbourne Electrical & Wiring 2 Sep 22nd, 05 05:02 AM
MSD 6AL ingnition box. Add a fuse ! Marc Electrical & Wiring 1 Oct 13th, 02 08:23 AM
Ignition terminal in 69' fuse panel drew69 Electrical & Wiring 4 Jul 24th, 02 04:22 AM
an FYI re electrical gremlins and the fuse panel backfire Electrical & Wiring 5 Aug 14th, 00 07:59 PM
