Outer Left Tail Light Won't Light Up - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 5th, 06, 10:10 PM Thread Starter
The outermost left tail light in my '67 RS/SS won't light up. I put in a new bulb and still doesn't light up. When I turn on the left turn signal, the green arrow on the dash just stays lit up and the front left turn signal light also just stays lit, likely because this outer left tail light doesn't light up. The other three tail lights (left inner, right inner and right outer) work fine. Looks like the wiring to this light is coming from the turn signal switch and the light switch/knob on the dash. Any ideas on what the problem could be? I don't think it's a bad ground since the left inner tail light uses the metal housing for a ground and it's working fine.
SFCamaro is offline
post #2 of 3 (permalink) Old Oct 6th, 06, 07:02 AM
Re: Outer Left Tail Light Won't Light Up
Sounds like you have a ground issue on the left side. Kinda odd cause it would usually take out both bulbs on that side too tho...
You might start by cleaning up the metal back of the tail light housing with some steel wool around where that socket plugs in, and clean/check the lil tabs on the socket that makes the connection. It never hurts to put a star washer under one of the nuts that secures the housing in the tail pan. Check the ground connection on the front parking light on that side, too. This is a ground wire with a ring terminal, in the lighting harness, that connects to the headlight support bracket.
post #3 of 3 (permalink) Old Oct 6th, 06, 01:05 PM Thread Starter
Thanks for the advice. I found the problem. The ground was fine. But the spring contacts in the socket were not fitting tight enough against the bulb contacts. I pulled up the spring contacts with a screwdriver to create a more tension against the bulb and now it works.
SFCamaro is offline
Turn signal & tail light not working SGcamaro Electrical & Wiring 0 Aug 21st, 05 05:34 PM
left RS light always opens up? MStennes Body Shop 1 Sep 8th, 03 09:21 AM
69 Tail Light Chrome Unreal Body Shop 3 Nov 17th, 01 11:53 AM
Tail Lights/Blinker Light stays solid MTidwell Electrical & Wiring 1 Oct 19th, 01 02:09 AM
Really Need Help with Tail Light Problem! daverichard Electrical & Wiring 8 Jun 16th, 01 07:58 PM
