Neutral saftey switch for B&M Pro rachet?? - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 16th, 06, 11:18 PM Thread Starter
6D9
Ron
I want to get to the track this weekend if possible but do not have the neutral saftey switch working in the car. Tranny is a TH400 with a B&M Pro rachet floor shifter. What is the best most straight forward way to hook this sucker up! I know from doing some searching that there is supposed to be the two large purple wires right??? Do I just use a Scotch lock to one of those wires and go the the supplied n/s switch?? Any and all help would be great! Thanks
69 Camaro
491/AFR 315'S/Straub hyd roller
TH400/GV OD
9" 3.50
6D9 is offline
post #2 of 7 (permalink) Old Oct 17th, 06, 02:30 PM
Re: Neutral saftey switch for B&M Pro rachet??
Yes, that will work. The purple wire is routed from the crank terminal of the ignition switch to the S terminal of the starter solenoid. If the NSS switch is open (not in neutral) current to the start solenoid will be interrupted. Put er in neutral and it will crank.
dnult is offline
post #3 of 7 (permalink) Old Oct 17th, 06, 04:07 PM Thread Starter
6D9
Ron
Thanks for the reply....I see there is two wires. Should I just tap into one of them?? What if I pulled them of the factory switch and changed to the female type connector to hook to the n/s switch. Thanks for the help!
69 Camaro
TH400/GV OD
9" 3.50
6D9 is offline
post #4 of 7 (permalink) Old Oct 17th, 06, 11:08 PM
Both wires need to run through the switch. The purple wire runs from the ignition switch through the neutral safety switch and then to the starter. The switch will only allow current to run to the starter when the trans is in park or neutral.
red67camaro is offline
post #5 of 7 (permalink) Old Oct 17th, 06, 11:17 PM
Sean
As others have said, use the purple wires in/out.
But I hate scotchlocks, they have to be the hoakiest means of wiring invented, nothing worse than opening a hood or looking under a dash and seeing wires spliced off of wires all over using those, plus they are a voltage drop waiting to happen.
What I did, was take (2) short (approx 2") pieces of wire, put a spade (male) connector on one end, sized to fit into the purple wires' factory end, and the female that fit the shifters neutral safety switch on the other end. then use that as a litlle "harness" to make the connection, it looks cleaner, is totally reversable, and wont destroy the wires your splicing.
There should be a switch there for your reverse lights too, I used the same method on them as well.
Sean
Franklin D. Roosevelt
68rs406 is offline
post #6 of 7 (permalink) Old Oct 18th, 06, 07:36 PM Thread Starter
6D9
Ron
68406...Could you send me some pics of it??? Thanks!
My e mail is [email protected]
69 Camaro
TH400/GV OD
9" 3.50
6D9 is offline
post #7 of 7 (permalink) Old Oct 18th, 06, 09:54 PM
Sean
Oh man, I knew you were going to ask that . I really don't have a good picture of it, heres the only one I have, and you can just barely see the connection at the switches,
You can see the connection at the reverse light/ neutral safety switches, and the other end is just a plug in to the existing connectors, using flat "spade" (male) connectors that fit into them. Really a piece o cake.
Next time I tear into the console, I'm going to take better pictures and dimensions of the whole set up.
Sorry I can't be of more help!
Sean
68rs406 is offline
Neutral safety switch on a manual 68? MikeC68 Electrical & Wiring 4 Oct 16th, 06 08:35 PM
Neutral safety switch for 67 manual trans? Rich67 Electrical & Wiring 3 Apr 26th, 06 11:51 AM
Ignition Switch? Neutral Safety Switch? planejane Electrical & Wiring 10 Jun 17th, 05 05:04 AM
Options for a '67 Shifter Neutral Saftey Switch? jknotts Tech 2000 6 Jul 27th, 01 07:34 AM
neutral saftey switch bigdaven Electrical & Wiring 2 Jun 14th, 01 07:49 PM
