HEI problems - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 19th, 06, 12:16 AM Thread Starter
Angry HEI problems
I have an HEI dist and today we decided to replace cap rotor and wires and plugs and coil. A basic tune up.. I have done this many times before so I feel silly for haveing to ask but after I put it all back together it won't start.. I did not remove the dist and I know I have the firing order right 18436572 . It is backfiring out of the carb and I can not figure out why. I have checked and double checked the wires and every thing looks like it is hooked up right... so I just don't know....
69 Camaro RS, 383ci,10.5-1 AFR 195's ported, Comp 286HR, 4340 forged Crank & Rods, JE Pistons, RPM Airgap, Holley 750 HP carb, 350 turbo w/ shift kit, 3000 Coan, Be cool, caltracs,12bolt 355 eaton posi..Best E.T. 12.22 @ 112
69CamaroRacer is offline
post #2 of 4 (permalink) Old Nov 19th, 06, 12:46 AM
madmax87's Avatar
Re: HEI problems
Any chance you may be one wire position off on where you have the number one plug wire? Bring engine up to TDC and pull cap off and take a quick look. If its 180 off, rotate engine 1 time and recheck.
madmax87 is offline
post #3 of 4 (permalink) Old Nov 19th, 06, 05:24 AM
Re: HEI problems
If it's backfiring out the carb then the wires went on in the wrong place. Do like Max said.
post #4 of 4 (permalink) Old Nov 21st, 06, 12:54 PM
Rob
Re: HEI problems
I agree. Had the same problem. Had HEI connected properly but in the exhaust protion of the cycle. Check like the gyys said and u will find that the rotor is not at #1 at TDC
'67 Rag Top, 350, Th 350, Frame off resto to an SS clone
hurdslake is offline
Will my Tic Toc Tac work with an HEI unit? JoshC Electrical & Wiring 4 Aug 30th, 05 03:06 PM
Upgrading to HEI... rp0029 Performance 14 Jun 28th, 05 06:44 PM
Stock HEI module or Accel? nitrous383 Engine 1 May 27th, 05 05:55 PM
Top dead center & ignition problems Tokyo Torquer Performance 15 Jun 5th, 04 01:59 PM
hei problems help!!!!!!!!! 1979 prostreet Troubleshooting 9 Mar 22nd, 02 02:53 PM
