How to terminate battery cables? - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 19th, 06, 06:56 AM Thread Starter
Rick
I have the DSE battery relocation kit and just installed the battery holder.
How do you put the brass ends on the cable(s)? Crimp? If so, do I need a die?
Thanks much.
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
post #2 of 3 (permalink) Old Nov 19th, 06, 07:21 AM
Re: How to terminate battery cables?
I used Taylor Brass 2 Ga. battery eyelet terminals (Summit part number TAY-21409), they solved all of my problems. You can get a picture and price at summit.com.
Larger Dave
Larger Dave is online now
post #3 of 3 (permalink) Old Nov 19th, 06, 11:11 AM
Steps
U meant the type where the cable goes into a hole on the back?
There are 2 ways
1/tin the cable (solder) and the inside of the hole, slide the cable in and solder
2/Crinp...this can be done by hand, thu best with the correct crimper...these are expensive and used by electritrians...next time the electrian is clalled into your work place or head down to the local work shop and ask him to crimp it.
I Tin the cable/terminal, then crimp, then flow the solder in
Remember to put the heat shink tube on the cable before crimping
Steptoe is offline
Rewiring the car... mbmmca Electrical & Wiring 13 Nov 23rd, 05 12:27 PM
Battery cables AJL69 Electrical & Wiring 5 Aug 2nd, 05 09:18 PM
Good Battery Cables dnult Electrical & Wiring 4 Apr 8th, 04 12:22 PM
Battery Cables, Amp Gage, Voltage Gage, Voltage Regulators, Alternators ...oh my!! Robert Stacho Electrical & Wiring 34 May 23rd, 02 12:30 PM
DieHard Security Battery Recall letter No 'E' in Camaro Electrical & Wiring 4 Nov 1st, 01 02:12 PM
