PED 56 Terminal Removal - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 20th, 06, 05:41 AM Thread Starter
Can anyone tell me how to remove the PED 56 terminals out of the connector?
ironhorse78247 is offline
post #2 of 4 (permalink) Old Nov 20th, 06, 07:41 AM
Re: PED 56 Terminal Removal
I know how to get most of them out, but can't recall what a PED 56 looks like. If you don't get the answer you're looking for, describe what it looks like.
dnult is offline
post #3 of 4 (permalink) Old Nov 22nd, 06, 08:41 AM Thread Starter
Here is a link with a picture of the terminal.
http://www.madelectrical.com/catalog/flat-blade.shtml
JG
post #4 of 4 (permalink) Old Nov 24th, 06, 08:40 AM
Ahh yes. For the female end, look at the connector end of the terminal. You'll see a tiny grove in the connector directly below the opening. Use a small brad, a tiny allen wrench or some other object that is faily small in diameter. A large bent paper clip may also work. Insert the object in the grove and it will depress the little metal tang that holds it in. The terminal should slip out the back side (wire side). Be sure to bend the little tang back out slightly if you plan to reuse the terminal. That brass doesn't have reall good spring tension and the removal tool will bend it in to the point the terminal won't stay in the connector any longer.
The male end is a bit different. You have to squeeze it width-wise. The picture you references shows how there is a diagonal slot cut in the terminal. Squeezing it shut will allow it to slip out the back as well. Again, you'll want to spread open the terminal a bit if you plan to reuse it.
dnult is offline
alternator problems continue orange 68 Electrical & Wiring 3 May 27th, 06 10:45 PM
Battery not holding a charge wrooster Electrical & Wiring 3 Oct 17th, 05 03:50 PM
No gen light, no charging. Almost ready for my first test drive! smith69z Electrical & Wiring 18 Sep 2nd, 05 01:01 AM
Arrrgh. Not all breakers have power... Why? efd75 Electrical & Wiring 6 Aug 12th, 05 03:54 AM
Extrernally regulated alternator wiring question Darin Imbriaco Electrical & Wiring 4 Jul 31st, 05 11:28 AM
