Horn Relay Buzzes New Relay - Team Camaro Tech
post #1 of 5 (permalink) Old Nov 21st, 06, 06:54 AM Thread Starter
Question Horn Relay Buzzes New Relay
Hey guys, I'm puzzeled on this one. When I switch my key to
ACC my horn relay buzzes, I can't seem to find out why. Can someone let me no of known problem. Thanks Mike
rookie68camaro is offline
post #2 of 5 (permalink) Old Nov 21st, 06, 07:12 AM
Re: Horn Relay Buzzes New Relay
Starting in 68, all GM cars had a "key buzzer" circuit. Changes included a new ignition switch with a "key in sensor", a different drivers door courtesy light switch with 2 male 1/4" spade connections, and some different wiring.
If you download the wiring diagrams from the "electrical basics" sticky, you can see the schematic, pm me for the password.
Tests: close the drivers door, did it stop?
Take the key out, did it stop?
Remove the pink / bk stripe wire from the horn relay, it stopped this time.
On mine, the "key in sensor" in the ignition switch is bad, it buzzes anytime the door is open whether the key is in or not. I just left the pink wire disconnected at the horn relay, don't need the darned car buzzing at me anyway!
post #3 of 5 (permalink) Old Nov 21st, 06, 08:33 AM Thread Starter
Hey Jim, With the key in, (door open or closed) the buzzer does not sound. it only sounds when I put or turn the key to ACC other than that, it does not buzz. Do you think I should just diconnect the pink black wire and move on. Thanks Mike
post #4 of 5 (permalink) Old Nov 21st, 06, 09:02 AM
yes. Unless you like it buzzing at you if you forget the keys... (yea, like any of us are gonna forget our keys!!) just pull the pink wire.
post #5 of 5 (permalink) Old Nov 21st, 06, 11:48 AM Thread Starter
Thanks Jim For All The Help
Horn Relay Buzzes When Key Is Inserted?? bdzee Electrical & Wiring 8 Nov 7th, 06 07:16 AM
horn relay wiring questions phishhead Electrical & Wiring 3 Apr 19th, 06 09:29 AM
Horn relay. Is it necissary? MarkM Electrical & Wiring 5 Aug 16th, 05 11:20 AM
Horn Relay wiring? kknapp433 Electrical & Wiring 4 Feb 6th, 02 11:36 AM
Horn relay problems 69 Blk69 Electrical & Wiring 4 Dec 2nd, 01 04:10 PM
