Fuse Panel - Team Camaro Tech
post #1 of 7 (permalink) Old Nov 25th, 06, 04:12 PM Thread Starter
Jerry
Smile Fuse Panel
This is shopman.I have a 1969 Camaro SS. Iwould appreciate it if some one could show me a picture of the fuse box panel. The name on some of mine are rubbed off. Just want to know what fuse is for what. Thank's.
shopman is offline
post #2 of 7 (permalink) Old Nov 25th, 06, 04:41 PM
JohnZ's Avatar
Re: Fuse Panel
Here's mine - the second from the top on the right you can't see is 25-amp for the wipers; the top cavity on the left is empty (no fuse clips). The extra center plug-in connectors are for the rear defogger and the ZL2 hood.
JohnZ
CRG
JohnZ is offline
post #3 of 7 (permalink) Old Nov 25th, 06, 05:18 PM Thread Starter
Jerry
Re: Fuse Panel
Thank's johnZ. Ididnot expect a answer so quickly. I also need to know what is the one on the bottom right.
shopman is offline
post #4 of 7 (permalink) Old Nov 25th, 06, 05:41 PM
Charles
Re: Fuse Panel
here's a pic of my old 69 box.
BELIEVE IN YOUR DREAMS
1969 SS X55 NOR added RS all NOS sheetmetal, ground up resto. 24 year project and dream. optioned out the wazoo. in one thousand pieces, and coming together finally.
Run269 is offline
post #5 of 7 (permalink) Old Nov 26th, 06, 06:33 PM Thread Starter
Jerry
Re: Fuse Panel
Thank's RUN269, this really helped a lot. Jerry
shopman is offline
post #6 of 7 (permalink) Old Nov 30th, 06, 06:01 AM
Re: Fuse Panel
I can't read most of the ones on my 68, so is the 68 the same as the 69. If it is this really helps me.
Thanks,
MGRII
MGRII is offline
post #7 of 7 (permalink) Old Nov 30th, 06, 09:01 PM
Larry
Re: Fuse Panel
The only real difference is the WIPER and HEATER fuse locations are reversed.
Larry
69-er is offline
Small Warp psalm69 Body Shop 4 Aug 25th, 03 06:39 PM
"Basics of Basics" Flat panel repairs MARTINSR Body Shop 0 Jul 14th, 03 06:59 PM
Flat panel repair "Basics of Basics" MARTINSR Body Shop 2 Aug 16th, 02 03:32 AM
Ignition terminal in 69' fuse panel drew69 Electrical & Wiring 4 Jul 24th, 02 03:22 AM
an FYI re electrical gremlins and the fuse panel backfire Electrical & Wiring 5 Aug 14th, 00 06:59 PM
