Dash Lights-Left Turn Signal - Team Camaro Tech
post #1 of 2 (permalink) Old Nov 30th, 06, 07:55 AM Thread Starter
I have a 1979 Z28 Camaro - the dash lights are out-left brake light out-left trun signal out. Everything else works fine. I tried changing the 3amp fuse but that did not help. Can anyone help?
cilla6791 is offline
post #2 of 2 (permalink) Old Nov 30th, 06, 08:55 PM
Larry
Re: Dash Lights-Left Turn Signal
Looks like you have quite a problem there! All of those circuits have separate fuses. I would first check the turn signal/brake light bulb, they both use the same filament in the bulb. Check the ground at the brake light too.
For the dash lights, do they work if you you rotate the light switch full counter clockwise? If they do, the rheostat in the switch has an open circuit. Even if they don't, you need to see if there is power coming out of the switch on the dark green wire. That goes directly to the instrument lights fuse. Tell us what you come up with.
Larry
69-er is offline
69 Camaro Turn Signal Cancelling Cam billscamaros Brakes, Suspension & Steering 2 Mar 20th, 06 06:00 PM
Turn Signal Dash Lights - What now? HELP! chedderboy Electrical & Wiring 9 Dec 26th, 05 07:59 PM
Help with 68 Turn Signal Mechanism sallman Camaro Tech 2 Aug 22nd, 05 08:42 PM
Left Tail light and turn signal problem Even10Flow Camaro Tech 2 May 30th, 05 03:25 PM
Dash lights/Running lights Frank Carvalho Electrical & Wiring 2 Mar 21st, 02 08:16 PM
