Tachometer Dies - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 3rd, 06, 04:27 AM Thread Starter
Andrew
Andrew69's Avatar
Tachometer Dies
My in-dash tachometer works most of the time but occasionally just drops to zero and rests. If I shut down the car and restart it works again. What is the fix?
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #2 of 3 (permalink) Old Dec 3rd, 06, 11:38 PM
Mel
Re: Tachometer Dies
Check the ground wire running off the tach (wire from back of tach to ground), usually a poor ground is the main culprit with most electrical gremlin's. Next I would recheck the tach lead (wire from back of tach to negative post on coil), and finally your ignition lead (wire from back of tach to ignition terminal at fuse box). There is no more. After that you may need to have the tach bench tested.
Good luck!!
Mel
69 Z28, DZ, M20, BU.
melav8r is offline
post #3 of 3 (permalink) Old Feb 3rd, 07, 06:35 PM Thread Starter
Andrew
Andrew69's Avatar
Re: Tachometer Dies
I still have problems with the in-dash tachometer failing. If I tap the lens cover with my finger tips it often comes back to life for a little while. All the grounds are fastened securely and the tach is connected in the back with a plug-in wiring harness, which itself is new. It is hard to see behind the tach, but is there a terminal that I could attach another ground wire to?
Any suggestions beyond removing it and bench testing.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
Tachometer DDD Electrical & Wiring 0 Jan 6th, 06 10:49 PM
Car starts but dies Lghtning38 Performance 3 Aug 1st, 05 11:59 AM
PUT CAR IN GEAR AND IT DIES!! mark67ss Engine 11 Jul 18th, 02 05:25 PM
Car idles down and dies when put into gear? Jeremiah Troubleshooting 1 May 6th, 01 04:18 PM
Engine dies at every stop. Ivan Troubleshooting 1 Feb 9th, 01 09:36 PM
