fuel sender unit - Team Camaro Tech
post #1 of 2 (permalink) Old Dec 3rd, 06, 04:40 PM Thread Starter
fuel sender unit
hi does anyone know what ohm sending units are used in 69 camaros
i bought a universal lever type 0 to 90 ohm unit as i have a small alluminum tank under my car i have the gm gauge for the fuel in the console the problem is when i hooked the sender up and left the lever and float down it read empty but when you raise it up to full the gauge only reads 1/4 tank on the gauge when you unhook the wire it goes to full
snoopycar z is offline
post #2 of 2 (permalink) Old Dec 3rd, 06, 05:12 PM
Re: fuel sender unit
90 ohms is correct. Are you positive you got a 90, it doesn't sound like it.
Your tests show the guage seem to be working normally.
98 V6 Fuel pressure drops after Key On Engine Off nascar9 Troubleshooting 3 Sep 28th, 06 07:30 PM
Correct fuel sending unit. jdjm Engine 2 Sep 20th, 06 09:23 PM
'67 Fuel Gauge Issue BW67 Electrical & Wiring 11 Oct 7th, 05 04:30 PM
fuel sender stamatisg1977 Engine 0 Oct 6th, 05 05:24 PM
fuel tank sending unit 69nj350 Tech 2003 20 Oct 8th, 03 08:23 AM
