Ballast Resistor, needed or not? - Team Camaro Tech
post #1 of 9 (permalink) Old Dec 5th, 06, 03:53 PM Thread Starter
I have a 327 with Mallory Unilite conversion in the distributor. I never ran a ballast resistor before but now that I am putting the engine back in after rebuild and doing all new wiring I am seeing reference to the resistor and wondering if I need it with Electronic Ignition. I plan on getting a new Mallory coil (threads are stripped on the old one) and perhaps a HyFire system down the road.
Thanks in advance,
Chris
forttusken is offline
post #2 of 9 (permalink) Old Dec 5th, 06, 05:40 PM
Doug
thedugan's Avatar
Send a message via Yahoo to thedugan
Re: Ballast Resistor, needed or not?
Are you running an ignition box? MSD 6al as an example? If so you do NOT need the resistor wire. If your not running an ignition box then you must use the resistor wire.
You can post a question on Mr. Gasket's website if you have questions.
Here is one question on the same subject from their website. http://go.mrgasket.com/AskTechResult...ID=1&ID=149584
-Doug
68 RS/SS Conv
67 Coupe
thedugan is offline
post #3 of 9 (permalink) Old Dec 5th, 06, 06:41 PM
Kevin
SixtyAte's Avatar
I use the Mallory Unilite setup and always ran with the resistor. See diagram below
Kev
https://www.camaros.net/forums/attach...1&d=1165372802
SixtyAte is offline
post #4 of 9 (permalink) Old Dec 6th, 06, 07:18 AM Thread Starter
Thanks! I guess I was just lucky all those years nothing got fried.
post #5 of 9 (permalink) Old Dec 6th, 06, 07:41 AM
I have been running my Unilite without an added resistor for 10 years. Doesn't the original wiring have a resistor already? Or am I just lucky too?
Brichead
Dan
67 Convertible
brichead is offline
post #6 of 9 (permalink) Old Dec 6th, 06, 10:41 AM
Dan
I ran quite a while with no resistor . The unilite fried just recently . Now I am using the resistor .
ranger is offline
post #7 of 9 (permalink) Old Dec 6th, 06, 01:51 PM
Brichead
The OEM harness did use a resistor wire. If that is the case, then no ballast resistor is needed. BUT notice that the ballast resistor only feeds the coil. The distributor needs a full 12V if schematic provided by SixtyAte is correct.
If you do have a resistor wire, it will be cloth covered and stiffer than the usual copper wires in the harness. Often the insullation will be cracked due to the head disappated by the wire. Also, the conductors will have a silver appearance - not bright copper (or tarnished copper) like the other wires in the harness.
dnult is offline
post #8 of 9 (permalink) Old Dec 6th, 06, 03:59 PM
chris
I ran the resistor and still fried my photo eye in the unilite. I put the hyfire box on it and have had no problems in about 12 years.
chris
67 camaro, 327/2004R<br />12bolt posi 4.10
cw67 is offline
post #9 of 9 (permalink) Old Dec 6th, 06, 07:13 PM
Kevin
SixtyAte's Avatar
The diagram is put out by th manufacturer not by me. If that is what they suggest to do, they made it so I follow what they say not maybe or maybe not
http://www.centuryperformance.com/mallory/wiring.asp
Kev
SixtyAte is offline
Do I need a ballast resistor? Fred Mertz Performance 2 Nov 17th, 06 09:48 PM
ballast resistor 5litre Electrical & Wiring 7 Mar 1st, 06 07:17 PM
red hot ballast resistor yellowrallys Electrical & Wiring 9 Jul 7th, 05 06:22 PM
ballast and resistive wire? kool Electrical & Wiring 3 May 15th, 05 05:07 AM
ballast zack 68 Electrical & Wiring 2 Feb 9th, 04 04:34 AM
