Horn Trouble - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 5th, 06, 05:28 PM Thread Starter
Horn Trouble
I have checked the wiring, jumped the horns which sound great and taken apart the steering wheel. The horn relay is fine. Nothing seems to work. Is there anything else I can try before I give up?
Mark Barons is offline
post #2 of 3 (permalink) Old Dec 5th, 06, 06:18 PM
Steven
Re: Horn Trouble
you need an ohm meter so that you can do a continuity check and test your grounds. Also, if you have newly painted surfaces, then that would also disrupt your ground at those points...
sdtsdt is offline
post #3 of 3 (permalink) Old Dec 5th, 06, 07:16 PM
Re: Horn Trouble
This link to a horn problem diagnosis paper may be of help.
http://jimshea.corvettefaq.com/wp-co...ACar13JN06.doc
JIML82
JIML82 is offline
Trouble Shooting Horn Relay mark67ss Electrical & Wiring 8 Dec 1st, 06 04:16 PM
horn trouble carhodge Electrical & Wiring 1 Aug 16th, 06 10:03 PM
horn trouble hammerandnailhandyman Troubleshooting 0 Aug 5th, 06 01:14 PM
Help with '68 Wood Steering Wheel Horn Cap Installation on a Tilt column ggkeller Interiors 2 Jun 29th, 05 05:32 PM
Camaro Horn trouble??? 69Tux Electrical & Wiring 1 Aug 27th, 03 07:36 AM
