headlight & headlightdoor / linked ? - Team Camaro Tech
post #1 of 2 (permalink) Old Dec 11th, 06, 08:17 AM Thread Starter
bruce
hard to explain, 67 rs had a bad headlight (lower beam part) & door would not oen or shut. Is this problem linked,because I changed bulb & door problem disappered. I have heard if bulb is bad, doors will do that to alert you of the bad bulb. Is this true or will this door act up again later Thanks for any tips.
egore is offline
post #2 of 2 (permalink) Old Dec 11th, 06, 06:13 PM
Re: headlight & headlightdoor / linked ?
The RS door circuit and the headlight circuit are separate. There is no alert feature. Perhaps you bumped a limit switch or a limit switch connector while you changed that bulb. If it acts up again I would check the limit switches and wiring by that bulb.
Marktat is offline
67 rs-ignition removal/tip on headlight wiring 67RS383 Electrical & Wiring 3 Apr 3rd, 10 06:17 AM
68 RS Headlight System Installed tim68rsss Restoration Corner 0 Mar 4th, 06 03:59 PM
Headlight relays questions.... whytry Electrical & Wiring 13 Feb 16th, 06 08:34 AM
67 RS headlight motor armature needed Mandra Restoration Corner 0 Jul 11th, 05 08:56 AM
Vacuum Headlight workings......Need Help Fireman1 Tech 2000 2 Jun 21st, 00 06:01 AM
