Grounding Question - Team Camaro Tech
post #1 of 10 (permalink) Old Dec 11th, 06, 10:21 PM Thread Starter
Grounding Question
I have just installed a power trunk latch in my 68 camaro and it does work, but it only works when the ground wire from the latch is grounded to the negative post on the battery. When i try grounding it to another ground on the car it doesnt work. The other spots that i tried are good grounds and i know because i have other things hooked up to those grounds and they work just fine, Any ideas why it only works at the negative battery post???
jshelzz is offline
post #2 of 10 (permalink) Old Dec 11th, 06, 11:25 PM
Fred
Re: Grounding Question
Oh man, that's a,,,what???? conundrum? That's illogical. Must be something simple. What and where did you try grounding to? I gotta believe that if other stuff works there, you are just not making good contact with bare metal. Too weird.
128.79mph 1.428 60'
Fred Ficarra is offline
post #3 of 10 (permalink) Old Dec 12th, 06, 06:58 AM
My first thought is that the negative cable to fender ground is bad. But if you say that other stuff works, then it sounds like your latch ground is bad. I'm with Fred - too weird.
dnult is offline
post #4 of 10 (permalink) Old Dec 12th, 06, 07:28 AM
click's Avatar
Have you tried using the star washers under the ground connection in the trunk area? I sense a bad connection to ground like the others. If the star washers wont bring it to life, Id make sure the fender lip ground next to the battery is also using star washers to grip the metal firmly. Do you have ground straps from the frame to the body below the heater box and from engine to firewall? Those help alot.
click is offline
post #5 of 10 (permalink) Old Dec 12th, 06, 08:32 AM
DjD
DjD's Avatar
The further from the Batt's grd post the connection is, the more resistance drop there will be. You'll see the grd, other items may not be as sensitive to the resistance drop but it sounds like your trunk latch is. Most likely the work that the switch has to do (releasing the latch) is a lot requiring a more direct connection to grd.
You can see this resistance drop by using a higher scale on you multi meter. Zero it out then measure continuity at the grd post and the connection to the fender. Then check from the grd post to the grd point you want to use. the 1st will zero the meter, the second won't...
Just run a lead to the fender grd and don't worry about it.
...Dennis
DjD is offline
post #6 of 10 (permalink) Old Dec 12th, 06, 09:26 AM
Fred
What a great web site. After my reply in #2 I thought of stuff to add. But when I came back here, others already had. This place is just like a race track. First one with the right answers wins.
128.79mph 1.428 60'
post #7 of 10 (permalink) Old Dec 12th, 06, 09:41 AM
DjD
DjD's Avatar
Fred you are right about it being a great site. The idea is the guy with the problem wins though not the guy giving the answer...
...Dennis
DjD is offline
post #8 of 10 (permalink) Old Dec 12th, 06, 09:54 AM
Fred
So true! But let me have my fantasies!
128.79mph 1.428 60'
post #9 of 10 (permalink) Old Dec 16th, 06, 05:36 AM
Bryan
Where did you get the power trunk latch? I haven't seen them before.
1968 Camaro, 383 with Dart Pro 1 aluminum heads and roller cam, Holley Sniper EFI with Dual Sync distributor, Muncie M21 4-speed transmission, 3.73 12-bolt Eaton posi differential.
Bry68 is offline
post #10 of 10 (permalink) Old Dec 16th, 06, 06:39 AM
The latches I recall ground through the housing and mounting bolts. If yours has a seperate wire then do the above recommendarions, although it will not hurt to make sure at least one of the bolts has a good ground and not nice clean paint etc.
TTFN
Mat
SSCARGO
Mat Klemp is offline
Engine Harness Question ironhorse78247 Electrical & Wiring 8 Nov 17th, 06 09:16 AM
am fm radio question flyers69 Electrical & Wiring 3 Jun 28th, 05 08:31 PM
carb and exhaust question for 67 RS small block Kyson Engine 2 Jun 25th, 05 12:40 PM
69 fuel line question - vapor return or not? Eric Kammerer Engine 7 Jun 11th, 05 06:08 PM
Front glass install question Brackneyc Body Shop 12 Jun 11th, 05 10:40 AM
