engine & elec run on - Team Camaro Tech
post #1 of 12 (permalink) Old Dec 12th, 06, 08:52 AM Thread Starter
When I turn off my 67, it stays on for just a second, I have checked and cleaned the grounds twice, and all seems well, what else could it be?
67Chef is offline
post #2 of 12 (permalink) Old Dec 12th, 06, 09:06 AM
Re: engine & elec run on
Do you have a stock electrical system? If it's not stock, what have you changed?
onovakind67 is offline
post #3 of 12 (permalink) Old Dec 12th, 06, 09:08 AM Thread Starter
All new elec system from painless
67Chef is offline
post #4 of 12 (permalink) Old Dec 12th, 06, 09:15 AM
Stock points distributor?
post #5 of 12 (permalink) Old Dec 12th, 06, 10:46 AM Thread Starter
Hei
67Chef is offline
post #6 of 12 (permalink) Old Dec 12th, 06, 03:48 PM
Bruno
Lightbulb Re: engine & elec run on
An electric cooling fan, by any chance?
"Our affair with Camaros is a life sentence without the possibility of parole".
ORENCH is offline
post #7 of 12 (permalink) Old Dec 12th, 06, 05:42 PM Thread Starter
Yes
67Chef is offline
post #8 of 12 (permalink) Old Dec 12th, 06, 06:35 PM
Are they the stock cooling fans?
post #9 of 12 (permalink) Old Dec 13th, 06, 02:44 AM
Bruno
Originally Posted by 67Chef View Post
Yes
Try electrically disconecting the fan. If the problem goes away, then the fan is retrofeeding the electric system, enough for the ignition to keep the engine on for a moment. I've heard people instaling a diode to solve that, but I haven't deal with that yet. I imagine the diode needs to be placed in the "correct" position and in the fan's 12 volts power wire.
ORENCH is offline
post #10 of 12 (permalink) Old Dec 13th, 06, 06:17 AM Thread Starter
I'll try that, thanks for the help.
67Chef is offline
post #11 of 12 (permalink) Old Dec 14th, 06, 06:39 PM Thread Starter
Orench,
I disconnected the fan and that did it, so I'll try the diode in the power wire and let you know if that works. Thanks for the help.
67Chef is offline
post #12 of 12 (permalink) Old Dec 14th, 06, 08:43 PM
It's going to take a helluva diode to handle the current if you want to put one in series with the fan. A diode also has a .7v drop across it, reducing the voltage to the fan. You're better off using an inline relay with a smaller snubber diode across the fan.
Learning from revamping blower engine Tokyo Torquer Performance 11 Jan 24th, 07 12:44 PM
One of my old 69 Z/28s is being missrepresented Rarerat Tag Team 106 Nov 8th, 06 02:33 AM
Low CR. Diesel Engine Fueled With Gasoline pdq67 Engine 13 Aug 30th, 05 07:21 PM
another engine run on NDubs68 Electrical & Wiring 1 Aug 27th, 05 08:09 PM
engine run on in ACC position dawg Troubleshooting 4 Aug 16th, 05 01:44 PM
