69 Tach Calibration - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 13th, 06, 04:22 AM Thread Starter
69 Tach Calibration
My tach is off by 1-2 hundred RPMS. Is there an adjustment or do I live with it?
Schoon
Schoon
SCHOON is offline
post #2 of 8 (permalink) Old Dec 13th, 06, 07:10 AM
Re: 69 Tach Calibration
I have the same problem with mine. Some people say there is an djustment on the tach itself, but I haven't taken mine out to find out. Hopefully will have time before spring. There was a post a couple of months ago about it.
Dave69Z is offline
post #3 of 8 (permalink) Old Dec 13th, 06, 12:54 PM
Fred
If there's an adjustment I never found it. When my car was new, one of the things on my corrections list for my dealer was to calibrate the tach. It was 300 rpm too fast. Also it had a loud lifter. (solid cam, 375hp) What else? Hey, I'm trying to remember, it's been 37 years!
Oh yeah, the front-end was way out of alignment. And there was a rust spot boiling up on the top of the front fender UNDER the paint. I made an appointment and dropped the car off. After work I picked up the car. Rust spot still there. Tach still read 300rpm. Started the engine. Lifter still knocked. I said 'did you even fix the alignment?'. They said, that's not covered. I said 'What is?'. They were out of business within a year.
Oh yeah, the tach! Three years later I took the tach out looking for an adjustment. Never found it, but did manage to stick something into the spring return and ruin it. A new one cost $70.00 and corrected the problem.
128.79mph 1.428 60'
Fred Ficarra is offline
post #4 of 8 (permalink) Old Dec 14th, 06, 06:52 AM
So it sounds like you never found the adjustment and had to buy a new tach. I am considering sending mine out for calibration but get a little worried about shipping it. For the cost i could probably buy and oer tach and install it if it works correctly? Anyone ever tried this?
Dave69Z is offline
post #5 of 8 (permalink) Old Dec 14th, 06, 02:11 PM
FWIW: I have looked at the guts of the OEM tach. They use a hybrid circuit with conductive ink resistors. If I recall, the adjustment was a laser trimming operation that partially cuts through the resitor ink. No tweaker to adjust. Perhaps other years were different.
dnult is offline
post #6 of 8 (permalink) Old Dec 14th, 06, 02:37 PM
Fred
Speaking of lasers,,, the ash tray light is fiber-optics. I'm sure everyone knows that. I thought the laser was invented later???? Nope, It's coming back to me. Apollo 11 planted a laser reflector on the Moon. July of 69.
Results just in! The Moon is moving away from the Earth at the rate of 2" a year. That's faster than continental drift!
What were we talking about?!
128.79mph 1.428 60'
post #7 of 8 (permalink) Old Dec 14th, 06, 04:24 PM
Farm Boy's Avatar
I adjusted the tach in my 67 and it works great! These old tachometers have a calibration potentiometer on the circuit board that can be accessed through a hole in the back of the tach. The adjustment hole was covered with a small round sticker. I removed the tach but I think the adjustment can be accomplished with the tach in the dash. You can use a small plastic screwdriver to make the adjustment (to avoid shorting out the circuits inside the tach). You can get a small plastic screwdriver at Radio Shack.
Farm Boy is offline
post #8 of 8 (permalink) Old Dec 15th, 06, 09:04 AM
Thanks for sharing that Farm Boy. Now I'm wondering what model year tach that was I worked on. I know the back of the tach was a round protruding stamped metal piece about 1.5" in diameter with three terminals sticking out of it. The hybrid circuit board inside was about 1.25" in diameter. At the moment I can't recall if the tach was round or square. A mind is a terrible thing to waste.
I'll have to add yours to my photo collection.
dnult is offline
tach problem MYSNAKES Troubleshooting 3 Dec 8th, 05 06:52 PM
Tach Problem On 1986 Iroc MYSNAKES Electrical & Wiring 2 Dec 7th, 05 06:02 PM
68 tach dirkey Electrical & Wiring 2 May 16th, 05 07:39 PM
adding a tach and guages.. 1968 327 timbo68 Performance 0 May 9th, 05 04:28 PM
