New wiper mototr question ??? - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 13th, 06, 05:30 AM Thread Starter
67 455 Bird ragtop's Avatar
I'm in the process of relocating my wiper motor to the outer fender well. I have a new motor and switch. I had it all wired up on the bench last night to make sure the motor was in the parked position before I start to modify the wiper linkage. The motor eran fine in both speeds. Well when I turned off the motor it kept running. It slowed down a bit like it was goig to stop. But then kept going.
If I put some pressure on the arm that is attached to the motor I can get it to stop. So I was wondering is this simply an issue of not having the drag of the wipers to stop it. Or is there a defect with this new motor?? I'm thinking that this new motor has a problem and should stop regardless of it being connected to the wiper linkage.
Thoughts ??
67 'Bird vert 455 JW TH400 KRE d-port 310 cfm heads H-beam rods Comp Cam 305-AH-8 cam w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Radials 31x18x15 on Convo Pro 15x15s
67 455 Bird ragtop is offline
post #2 of 3 (permalink) Old Dec 13th, 06, 07:52 AM
Re: New wiper mototr question ???
Without the linkage they will often overrun the park switch. If it stops with a drag it's probably OK.
go2fast is offline
post #3 of 3 (permalink) Old Dec 13th, 06, 08:48 AM Thread Starter
Thanks. That's what I figured. I'll proceed with that in mind.
Second generation 70 Z28 question nikkisdad Second Generation 17 Jan 5th, 15 03:34 PM
68 Drum to Disc upgrade (silly question?) AussieCamaroOwner Brakes, Suspension & Steering 3 Feb 18th, 06 03:56 AM
Wiper Switch Question mjm7496 Electrical & Wiring 6 Apr 5th, 05 10:41 AM
dumb 4Gen wiper question pdq123 Body Shop 2 Mar 2nd, 05 05:22 PM
wiper question .... JWLambertson Electrical & Wiring 1 Mar 18th, 04 05:03 PM
