Fuse problems - Team Camaro Tech
post #1 of 9 (permalink) Old Dec 16th, 06, 02:05 PM Thread Starter
Fuse problems
When I turn on my headlights, the tail-light fuse begins to burn....Any thoughts on where to start tracing the short???
varsity69 is offline
post #2 of 9 (permalink) Old Dec 16th, 06, 03:57 PM
Kevin
SixtyAte's Avatar
Re: Fuse problems
It sounds like you have a short in the wiring to the tail lamps. Follow that wire from the tail lamp to the light switch. It runs along the drivers side of the car.
Kev
SixtyAte is offline
post #3 of 9 (permalink) Old Dec 16th, 06, 04:00 PM
Re: Fuse problems
removing stuff is a good way to find a short. There is a connector above the e-brake assy, maybe back behind the kick panel a lil, that takes all the power to the back of the car. If you disconnect it and then the fuse doesn't go, the problem is further back. Next you might try removing all the tail light bulbs. Then pull the door sill, peel up the carpet and inspect the wiring for damage, then do the same after pulling the backseat.
post #4 of 9 (permalink) Old Dec 16th, 06, 04:02 PM
Steven
Re: Fuse problems
Assuming you haven't done any wiring lately, I would start by looking at the tail light sockets ... then check for flayed wiring
sdtsdt is offline
post #5 of 9 (permalink) Old Dec 16th, 06, 04:09 PM Thread Starter
Re: Fuse problems
Thanks I'll give it a short....I mean a shot
post #6 of 9 (permalink) Old Dec 19th, 06, 10:23 AM
Re: Fuse problems
I had this same issue after replacing all my wire harnesses a couple years back.
I had installed new harnesses from M&H. Then the problem showed up. I disonnected the rear harness from the connector up near the fuse block and still had the problem. Then I disconnected the front light harness from the bulkhead connector in the engine compartment, and the fuse stopped blowing. I pulled that new harness out and took it over to M&H. They tested it and it was good, and being the swell guys they are they gave me a replacement harness anyway. When I installed it, the problem was gone. M&H suspected I had a short in one of the sockets that they for some reason could not detect. The only noticeable issue with the harness that was blowing my fuses, is they had not greased it with that gooey black goopy stuff and I installed it any way. Replacement harness was gooped.
Follow the advice already posted on the brake lamps etc. But also check your parking and marker lamps. The side marker lamps can sometimes short in the socket if the leads are not straight.
Narrow it down to the front or rear harness by disconnecting them one at a time and then turning the lamps on to see which harness makes the fuse blow.
Buy a couple boxes of 20A fuses and then go one socket at a time. Remove the bulb, turn on the lamps and see if the fuse blows. Sooner or later you'll find the right socket, then you can narrow it down to the socket, the bulb or the wiring to that socket.
If you have to, pull the suspect harness out and inspect the entire length for damage. It's not as hard as it sounds.
Also check all your grounds to be sure they are clean.
Also inspect the headlamp switch wiring in your main harness uneder the dash. Headlamp switches get corroded over time and are pretty cheap, so if nothing else works out, replace the switch.
Tim
Meanchicken
68 SS
ZZ502; TKO-600; 3:73 Moser 12-bolt w/Detroit TruTrak; SSBC Force 10 4 wheel power disks;QA1 Coil Overs; Global West Tubulars;GNX Quick Ratio 12:1 PS; Hotchkis Front Sway Bar
87 Buick Grand National (does 10's)
Meanchicken is offline
post #7 of 9 (permalink) Old Dec 19th, 06, 10:25 AM
Re: Fuse problems
Also inspect the headlamp switch wiring in your main harness under the dash. Headlamp switches get corroded over time and are pretty cheap, so if nothing else works out, replace the switch.
Tim
Meanchicken
68 SS
post #8 of 9 (permalink) Old Dec 19th, 06, 10:27 AM
Re: Fuse problems
Sorry for the double post....my Blackberry went hay wire on me.
Tim
Meanchicken
68 SS
post #9 of 9 (permalink) Old Dec 19th, 06, 10:43 AM
Harley
wiskeesour's Avatar
Re: Fuse problems
I have found some wires on a few of the cars I worked on to be shorted INSIDE the fuse box.
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
fuse box problems jdbr1 Electrical & Wiring 3 Jun 29th, 06 08:02 PM
fuse help 400bird Electrical & Wiring 4 Jan 31st, 06 01:29 PM
Fuse Panel Help! Pics included 67RS RAG Electrical & Wiring 10 Apr 18th, 05 10:19 PM
Tail Lamp Fuse Blowing dschribs Electrical & Wiring 1 Aug 17th, 03 02:57 PM
MSD 6AL ingnition box. Add a fuse ! Marc Electrical & Wiring 1 Oct 13th, 02 07:23 AM
