More problems with console gauge set - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 19th, 06, 05:48 PM Thread Starter
I've started to assemble a second center console with the 4 gauge set forward of the shifter. I have a new console wiring harness and a sealed repo OER 4 gauge cluster assy. The AIM on page 415 (u17/a2) shows a wire with a connector on it coming out thru a hole in the mounting plate from the face side of the fuel gauge. This wire connects to a yelllow wire in the console harness. My gauge set does not have this wire at the gauge. What can I do? Is it maybe not needed with a repo gauge pack? The back of this fuel gauge does not look the same as the drawing in the AIM. But the 2 wire connector at the fuel gauge is there and matches with the harness.
Is there a wiring diagram for this optional gauge set? I have only been able to find the std dash (idiot) light diagram.
I need as clue.......
Hope this makes sense,
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:73.
Fred Mertz is offline
post #2 of 8 (permalink) Old Dec 19th, 06, 06:22 PM
madmax87's Avatar
Re: More problems with console gauge set
That may be for the low fuel warning light. It would flash inside of your fuel gauge readout so you would notice the fuel level. My original cluster had it but I'm not exactly sure of the color of the wire.
madmax87 is offline
post #3 of 8 (permalink) Old Dec 19th, 06, 06:32 PM Thread Starter
I just took a break and got some food. I started thinking the same thing. I don't think the extra wire is a big deal.
__________
post #4 of 8 (permalink) Old Dec 19th, 06, 06:47 PM
Fred, The yellow wire is for the low fuel module. There's a small can that mounts with the gauges, and a yellow light "somewhere" in the dash (I only know where on a 68.) Check your email for some christmas presents that will help.
post #5 of 8 (permalink) Old Dec 19th, 06, 08:16 PM Thread Starter
I see the OE setup has a lot more grd. wire connections. I may add a few just for safe keeping.
Thanks again Jim,
__________
post #6 of 8 (permalink) Old Dec 20th, 06, 07:25 AM
click's Avatar
here is my low fuel I taped to the inside of the guage cluster. Yellow wire feeds it.
click is offline
post #7 of 8 (permalink) Old Dec 20th, 06, 07:33 AM
I emailed him schematics and all your pictures Jim.
post #8 of 8 (permalink) Old Dec 20th, 06, 10:59 AM
click's Avatar
thanks Jimbo
click is offline
69 console temp gauge not working garyj Electrical & Wiring 3 Jul 22nd, 06 12:32 AM
Console Gauge issue HawkX66 Electrical & Wiring 2 Nov 1st, 05 12:53 PM
'68 console temp gauge rear diagram fastred57 Electrical & Wiring 0 Oct 10th, 05 11:53 AM
console oil press gauge leaks BAMiller Interiors 13 Aug 18th, 05 06:00 PM
Wiring problems with console fuel gauge Jeff H Tech 2000 1 Nov 15th, 99 04:40 AM
