brighter headlights with no relays - Team Camaro Tech
post #1 of 16 (permalink) Old Dec 24th, 06, 12:54 PM Thread Starter
Question brighter headlights with no relays
I'm looking to install slightly brighter headlights and not have to install relays etc. I prefer to keep the wiring stock. Anyone know of such headlights??
utility5 is offline
post #2 of 16 (permalink) Old Dec 24th, 06, 02:49 PM
Kevin
SixtyAte's Avatar
Re: brighter headlights with no relays
Try using a newer type bulb like the Sylvania Brite White for about $20.00 each. The best way is to follow what is done here in the link http://www.madelectrical.com/electri...adlights.shtml
Kev
SixtyAte is offline
post #3 of 16 (permalink) Old Dec 24th, 06, 03:54 PM
Going with a higher wattage bulb is only going to dim the dash/rear tail/brake lights more. The stock wiring system just cannot handle that kind of electrical draw well. Buy the relays, they are cheap.
30 Amp Relays $1.39 each
http://www.partsexpress.com/pe/showd...number=330-073
12V 5Pin relay socket with 12" 14 gauage pigtails $1.75ea
http://www.partsexpress.com/pe/showd...number=330-075
12V 5Pin Dual Relay socket with 12" leads $1.90ea (Only Need 1 for Headlights)
Ring Terminal Kit - $11.09
http://www.tessco.com/products/displ...=4&eventPage=1
or
#10 (16-14) Ring Terminal 50 pcs $2.95
http://www.partsexpress.com/pe/showd...number=095-214
Butt Splice (16-14) 50 PCS $3.25
http://www.partsexpress.com/pe/showd...number=095-252
Black Heatshrink (4ft) $2.13
http://www.partsexpress.com/pe/pshow...number=082-034
Dorman 60361 Fusible Link 14ga $2.54 from RockAuto.com
If rewiring to the headlights, get 14 gauge at Pep Boys for $6, else Butt Splice into existing wiring harness!
Great for headlights or replacing the horn relay!
and
Brian Lewis is offline
post #4 of 16 (permalink) Old Dec 24th, 06, 06:32 PM Thread Starter
thanks guys - I haven't done any research - I was hoping there was a newer type (halogen?) bulb that used the same wattage, and was brighter. I agree the relay is obviously better - I'm kinda anal about the stock wiring. Any other ideas??
utility5 is offline
post #5 of 16 (permalink) Old Dec 24th, 06, 06:41 PM
There are absolutely halogen replacments for the stock headlight bulbs. The most common are also a sealed beam type, the same wattage as stock, and replace the original lights exactly.
I use them (without relays) and they give a much "better" light than stock.
The relays are a good idea, and will help the brightness of any headlight bulb by eliminating voltage drop in the wiring.
post #6 of 16 (permalink) Old Dec 24th, 06, 09:30 PM
Tony
Are they the bright white kind? Where do they sell them?
67 Camaro- 427BB, TKO 600, 3.55 12 bolt etc.etc.
italiano362 is offline
post #7 of 16 (permalink) Old Dec 25th, 06, 05:22 AM
Bill
The relay install is very easy and you get all the parts to make it look stock.
There are 2 relays, 1 for low beam the other for high beam
bills69 is offline
post #8 of 16 (permalink) Old Dec 25th, 06, 05:57 AM
replacement sealed beam halogons are sold in every auto parts store, or even the auto department at walmart.
post #9 of 16 (permalink) Old Dec 25th, 06, 06:01 AM
Classic Industries makes a kit that PLUGS IN to the stock wiring harness and provides relays. Its only about $22 I think
and
post #10 of 16 (permalink) Old Dec 25th, 06, 07:54 AM
Chris
check-out the Sylvania "Silverstar" hi-performance halogen units. direct plug-in units. part # for a Camaro is H6024ST. the box reads:"whitest, brightest, 100% street legal". they yield excellent lighting while maintaining a stock-appearance, and required no modifications to the wiring.
'69 SS X66 Camaro
454, TH400 & GearVendor, 12 bolt
'82 Corvette.
stock
'81 Camaro Pro Bracket car.
406, TH350, 10 bolt, NHRA #3148
82Vettrin is offline
post #11 of 16 (permalink) Old Dec 26th, 06, 12:23 PM Thread Starter
One thing that comes to mind if I install the relays etc. is the fact that my dash lights will be brighter because of more voltage at that location. But the dash lights will burn-out sooner... and you know how much a pain in the .. they are to change.
Brian, where in the Classic catalogue did you see the plug-in kit??
utility5 is offline
post #12 of 16 (permalink) Old Aug 18th, 07, 08:14 AM
Jeff
yellow69RS's Avatar
If I was doing it I'd put the relays in the headlight circuit between the headlight switch and the dimmer... Then the headlight gets the higher voltage and the rest gets normal voltage as factory designed. One relay would do high and low.If you use a relay like a common fuel pump relay with terminals labeled 30, 85,86,87,87a. Hook it up like this wire from h/l sw to 85, hook 86 to ground, put battery to 30, and wire to dimmer to 87, 87a not used. It's not as hard as you think! Any ? feel free to PM
Jeff
yellow69RS is offline
post #13 of 16 (permalink) Old Aug 18th, 07, 08:20 AM
Maybe you ought to see if you can find a car that has a dash light dimmer control and swap that into your car. I think you can find these to fit the original wiring system.
onovakind67 is offline
post #14 of 16 (permalink) Old Aug 18th, 07, 01:55 PM
The OEM wiring wasn't up to par as it was. The relay upgrade helps the OEMs. If you go to an upgraded lamp, that's even more of a reason to install relays IMHO.
dnult is offline
post #15 of 16 (permalink) Old Aug 20th, 07, 06:53 AM
I wired my headlights using MAD Electric wiring diagram. The fellow that owns MAD Electric knows his stuff on automotive wiring. He believes in relays. One of the best things I did was put relays on my headlights and electric fans. Have bright headlights and fans are workinga full power with no drop in voltage.
502prostreet is offline
relays relays relays HLSASS Electrical & Wiring 10 Oct 3rd, 05 10:06 AM
Brighter Headlights KRhat Electrical & Wiring 9 Mar 13th, 04 05:07 PM
Brighter Headlights mr69 Tech 2001 12 Dec 28th, 01 12:56 PM
brighter headlights Murfys_Law Tech 2000 17 Nov 7th, 00 06:27 AM
Brighter headlights? SAyers69 Tech 2000 6 Mar 12th, 00 06:29 AM
