Wire terminal removal - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 26th, 06, 02:29 PM Thread Starter
Okay, this should be simple, but I'm a rookie. I'm installing a new under dash harness to go along with the new console gauges on a 69. How do I get the original wires plugged in behind the fuse panel to release so I can replace them? I've tried inserting a small screw driver, but no luck.
chucksodowsky is offline
post #2 of 5 (permalink) Old Dec 26th, 06, 04:16 PM
Re: Wire terminal removal
There is an upper and lower clip on both plugs......release them both while working the plug up and down. Remember....it's been there for awhile, so you'll have to work it a bit.
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 5 (permalink) Old Dec 26th, 06, 07:07 PM
Chuck -
Are you trying to get the two connectors (engine harness and front light harness) on the engine side of the fire wall off the fuse box? If so there is a screw in the center that holds the two on. It actually only screws through the engine harness, but the front light harness clips into it, making it one unit for removal and assembly.
Or are you trying to replace only the dash harness and reuse your fuse box? If so, the terminals in the fuse block are blades, with a slot cut into the middle so they will flex for removal. I have a couple laying around that I can photograph, but if you look close at them you should see the slot. Then you go into the well on the block with a really thin small screwdriver (like a jewlery screwdriver) and flex the clip to get it out. You need to go in on the narrow sides of the terminal, not the flat wide sides.
See if I can explain with crude computer graphics. If this ! is the terminal seen from the end, with the slot being the space between the top and period, you need to lift on it like this:
Eric
Eric Kammerer is offline
post #4 of 5 (permalink) Old Dec 26th, 06, 10:02 PM
Farm Boy's Avatar
Flatten the end of a straightened out paperclip with a hammer. Use the flat end to depress the tang holding the terminal in.
Farm Boy is offline
post #5 of 5 (permalink) Old Dec 28th, 06, 05:42 AM Thread Starter
I will have to remove the harness from the firewall side as well, but the current problem is removing the individual wires from behind the fuse block on the interior of the car. I will try the paperclip approach. I have tried a small screwdriver, but it might not have been small enough. If you do have a picture of the removed clip, I would greatly appreciate it.
Thanks for the advice.
need info on broken plug wire on alternator jaytone Electrical & Wiring 4 May 25th, 06 04:10 AM
No gen light, no charging. Almost ready for my first test drive! smith69z Electrical & Wiring 18 Sep 2nd, 05 01:01 AM
PO 300 301 302 OBD II 3L 4P Bench Racing 9 May 6th, 05 07:02 PM
welding....need help 69ss350camaro Body Shop 3 Apr 3rd, 03 01:20 PM
Expanded MARTINSR Body Shop 11 Jan 15th, 03 01:57 PM
