fuel gauge problem - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 26th, 06, 04:22 PM Thread Starter
Paul
fuel gauge problem
Hi TC, I'm still having problems with my console fuel gauge on my '69. I purchased a new console gauge assy. from Matt's Classic Bowties month's ago and only recently put it in. My fuel gauge is at 1/4. I measured the sender wire in the trunk to grd. and got 80 ohms (close to full) and again behind the gauge and got 83 ohms. I still need to drain about 5 gallons out of the tank and hopfully my ohm reading will drop. I reconnected my wires and still read the same as I started. I lifted the sender wire behind the gauge and the needle stayed and didn't go to full. I connected a 40 ohms resistor to the gauge sender terminal to ground and the needle went to 1/4 full. I shorted the gauge sender terminal to grd. and the needle went to "empty". My volts is at 12v. and the ground seemed to be good. I even ran a jumper from the batt(-) to behind gauge (stud). My other gauges seems to be working along with all bulbs. Do I need a shunt resistor across the terminals of the gauge and if so, what size? I know I read it somewhere about the resistor, but need to confirm. I won't be able to work on car till the weekend but, any help would be appreciated. Thanks!!
69rszee is offline
post #2 of 6 (permalink) Old Dec 26th, 06, 10:38 PM
madmax87's Avatar
Re: fuel gauge problem
The new after market gauges do not require a shunt resistor. Sounds like you may have a bad new gauge.
madmax87 is offline
post #3 of 6 (permalink) Old Dec 26th, 06, 11:30 PM Thread Starter
Paul
Thanks Dennis, i'm still gonna try and drain some fuel out of the tank to further isolate my Fuel Sender and connect a variable resister to simulate my senders resistance @ the gauge. Anybody else thinks the problem is the gauge.
69rszee is offline
post #4 of 6 (permalink) Old Dec 31st, 06, 06:00 PM Thread Starter
Paul
Happy New Year everyone! Still having problems with my fuel gauge. I connected a potentiometer to my gauge ref to ground and the highest I could get was about 1/4 full with 40 ohms. I again lifted the ground and gauge didn't go to full. And remember I was getting 80 ohms at the sender wire in the trunk, now i'm getting 140 ohms. I drained about 5 gallons of fuel and my multimeter showed 2k ohms. So weird and frustrated. I came to the conclusion that my new fuel gauge and sender unit is bad. Never replaced my sender unit before, do I also replace the o-ring, locking ring and any other item? Thanks again! Have a safe and Happy New Years.
69rszee is offline
post #5 of 6 (permalink) Old Dec 31st, 06, 06:08 PM
madmax87's Avatar
Happy New Year to you too! When you order your sending unit, it should come with a new o-ring, but might ask so your not waiting again for parts. Replace the o-ring but use your original locking ring. The aftermarket rings are crap.
One other thing, did you check your ground wire on the back of the gas tank from the sending unit. (Axle side) It's held on by a small screw going to a bracket. Make sure you have a good and clean connection there.
madmax87 is offline
post #6 of 6 (permalink) Old Dec 31st, 06, 06:13 PM Thread Starter
Paul
Thanks Dennis!
69rszee is offline
Wiring Issue After Engine Swap Help Please!!!! tourville87 Camaro Tech 7 Nov 20th, 06 06:52 PM
Wiring Issue After Engine Swap Help Please!!!! tourville87 Engine 0 Nov 11th, 06 01:59 PM
fuel tank fuel gauge problem nova73 Electrical & Wiring 2 May 13th, 06 09:15 AM
Fuel gauge Issues. 68camrs Electrical & Wiring 9 Jan 1st, 06 01:50 AM
