quick painless wiring question... what is this wire? - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 26th, 06, 08:37 PM Thread Starter
Ryan
Hey guys, I was just wondering if anyone knew what the tan wire went to? Im almost positive that the blue one goes to the wipers since thats the only place it reaches but I cant seem to find where the tan one goes... any help would be appreciated. Thanks!!
http://i36.photobucket.com/albums/e42/ryperry/wires.jpg
ryry is offline
post #2 of 5 (permalink) Old Dec 26th, 06, 09:34 PM
Russ
Re: quick painless wiring question... what is this wire?
which tan one are ya talkin' about??
there should be quite a few of them.
#909 Tan Low Beam Dimmer Switch
#917 Tan Inside - Foot Lever Switch Emergency Brake
#972 Tan Outside - Low Pressure Switch Emergency Brake
#903 Tan Cigarette Lighter
#970 Tan Instrument Panel Brake Warning Light
#909 Tan Low Beam Headlight Section
all of the wires in Painless harness should be numbered...
Blown 69 RS Camaro
383 Small Block
Dyno: 578 Horse - 595 LB/Torque
Blown69RS is offline
post #3 of 5 (permalink) Old Dec 26th, 06, 09:48 PM
That Blue could also be the oil pressure sending wire, if Painless follows normal convention. Aren't the wiper motor wires grouped in the painless harness?
The tan in your photo looks like the brake warning switch wire. It looks like a round terminal, to fit over the post on the switch in the background of the photo.
Glad I got American Autowire...
Eric
Eric Kammerer is offline
post #4 of 5 (permalink) Old Dec 26th, 06, 09:50 PM Thread Starter
Ryan
oops, I forgot to say its under the hood (I had written the post then my computer screwed up). Its about 9 inches long and its not numbered on the wire (like every other wire is). however, I think it might be wire 972... that wasnt listed in the instructions I have. Thanks for the help!!
Ryan
ryry is offline
post #5 of 5 (permalink) Old Dec 26th, 06, 10:02 PM
Russ
yep, the one in your picture is for the Brake warning switch... round terminal should push over connector on brake dist. block.
Blown 69 RS Camaro
383 Small Block
3 wire alternator wiring help! WKreidler Electrical & Wiring 3 Jul 3rd, 06 05:33 PM
Painless vs. Classic Wiring Advice ( criddell Electrical & Wiring 14 Apr 8th, 06 08:10 AM
TPI Painless Wiring Swap 5speed Electrical & Wiring 4 Dec 30th, 05 10:27 PM
1967 Camaro 350 Ignition wiring question Mean_Gene3 Engine 6 Oct 2nd, 05 11:50 AM
V8 Wiring Question V8Mario Tech 2000 3 Oct 16th, 00 08:08 PM
