ohm sweet ohm / 69Maro fuel sending unit - Team Camaro Tech
post #1 of 9 (permalink) Old Dec 27th, 06, 02:35 PM Thread Starter
chris
I am trying to read the ohms on a brand new fuel sending unit for my 69 camaro (350). The problem is I only get 54 ohms at "full tank" on it. (And 0 ohms at empty tank)
I thought that the factory sending units were supposed to be 90 ohm at full and 0 at empty???
I am checking this with a digital ohm meter connected to the lug on the top of the unit and to the body of the unit.
This is the second time I have seen this and am wondering if it's just another bad (brand new)unit???
chrisp1 is offline
post #2 of 9 (permalink) Old Dec 27th, 06, 03:19 PM
Kevin
SixtyAte's Avatar
Re: ohm sweet ohm / 69Maro fuel sending unit
Yes, 90 ohms is correct. You should ground the unit then try again to see what it shows for ohms.
Kev
SixtyAte is offline
post #3 of 9 (permalink) Old Dec 27th, 06, 03:23 PM
you do have the circuit disconnected, right? You pulled the connector in the trunk or at the sender?
post #4 of 9 (permalink) Old Dec 27th, 06, 05:39 PM
Kevin
SixtyAte's Avatar
Jim,
I read it as he has the unit in hand and not in the tank. That is why I said to be sure and ground the unit. Could be wrong..
Kev
SixtyAte is offline
post #5 of 9 (permalink) Old Dec 27th, 06, 08:12 PM Thread Starter
chris
Guys,
I am checking this brand new, never installed unit, as I hold it in my hand not in the car.
The deal is that this is the second new one to read exactly 54ohms at full tank. The first one I sent back because I thought it was faulty.
I should be reading 90ohms right?
Has anyone else thought to check the ohms on a new sender before installing it??
Only other option, I am thinking, I need to try another fluke meter for a second opinion.
Thanks for the input and I wish I could have posted sooner!
chrisp1 is offline
post #6 of 9 (permalink) Old Dec 28th, 06, 07:00 PM
Larry
chrisp1,
You are checking the resistance correctly. By connecting one of the voltmeter leads to the body, you are effectively "grounding" it. Sounds like a bad one to me too.
Larry
69-er is offline
post #7 of 9 (permalink) Old Dec 30th, 06, 07:32 AM Thread Starter
chris
This seems crazy but....
I tested the sending unit with a different digital multimeter (Fluke) and still 54 ohms.
Then tested it with an analog meter (Sperry)and now 90 ohms
ChrisP
chrisp1 is offline
post #8 of 9 (permalink) Old Dec 30th, 06, 08:57 AM
Larry
I wonder if you have a calibration problem with the Fluke. You could go to Radio Shack and get a few resistors to check the meters. Right now, you have a 50-50 chance of the sender being bad.
Can you temporarily connect the sender to the gauge, power up the system, and see how the gauge reacts? I think that would be the ultimate way to test it.
Larry
69-er is offline
post #9 of 9 (permalink) Old Dec 30th, 06, 03:23 PM Thread Starter
chris
Larry
Larry,
I will connect to the gauge as a sure fire way of knowing if the sender is bad before I install it in the tank, but I just think its kinda strange that two digital Flukes are reading the exact same(54ohms), and an analog meter reading perfect 90ohms.
Good idea on checking with a resistor, I'll try that. But, the digital meters should not need calibration as one is new and the other is just a few months old. I'll check anyway.
ChrisP
chrisp1 is offline
Fuel Tank & Sending Unit Question. FBODY Electrical & Wiring 11 May 23rd, 06 05:27 PM
fuel tank sending unit dusted800 Performance 1 Feb 12th, 05 09:43 AM
fuel sending unit libb58 Performance 2 Feb 10th, 05 03:44 AM
Where can I get a stock 3/8 fuel pickup with sending unit for 73 Nova? thrasher Performance 8 Apr 9th, 04 09:37 PM
fuel sending unit emtcee1973 Performance 1 Dec 30th, 03 12:09 PM
