1967 Fuse Panel - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 28th, 06, 08:02 AM Thread Starter
Smile 1967 Fuse Panel
Well I crawled under the dash to examine the fuse panel/right side with the male spades. My car has the following accessories:
Rear Defogger which is a dark brown wire.
Console Clock which is a orange wire.
Ash Tray Light (under the AM radio) which is a gray wire.
Which male spade do these plug into? I think the defogger should be in the ACC, the clock in the BAT and the ashtray light in the IGN.
I also have a Secret Audio AM/FM radio that I believe should plug into the pigtail of the clock/BAT spade.
Thanks Ken
Weave67RS is offline
post #2 of 3 (permalink) Old Dec 28th, 06, 07:11 PM
Re: 1967 Fuse Panel
I would put the defogger on the IGN, the clock on the BAT, and the ashtray light on the LPS. This way the defogger will only work when you're in the run position, the clock will run all the time, and the ashtray light will come on and dim with the dash lights.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 3 (permalink) Old Dec 29th, 06, 07:41 PM
Robert
Re: 1967 Fuse Panel
hey Ken .. sorry to tread on your thread but since you posted fuse panel I have a fuse panel question but I posted in the troubleshooting ......... if you guess can check it out I would apreciate it .. I took a pic of the fuse panel . I first started out with tail light problem " fixed but now I have a fuse box question....https://www.camaros.net/forums/showthread.php?t=97215
once again Sorry Ken .. I hope you find out what your problems is .. Im having problems my self .
Rob.
RobSS1113 is offline
Fuse Panel shopman Electrical & Wiring 6 Nov 30th, 06 09:01 PM
Fuse Panel Terminal Riccbhard Electrical & Wiring 4 Oct 19th, 05 07:01 AM
Trunk lid gap skreese Body Shop 3 Sep 4th, 03 03:48 PM
"Basics of Basics" Flat panel repairs MARTINSR Body Shop 0 Jul 14th, 03 06:59 PM
Panel Alignment (MARTINSR) cpodeep Body Shop 12 Apr 7th, 02 01:01 PM
