all gauges don't work - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 30th, 06, 09:01 AM Thread Starter
Is there some harness or something that could be disconnected that would result in all my gauges not working? I checked the circuitboard on the back of the dash...thats GOOD. all the fuses are GOOD. The harness is connected, and I doubt the sending units are all bad. Just curious if there is anything in the middle of those connections that I might have missed?
Prelude00782 is offline
post #2 of 3 (permalink) Old Dec 31st, 06, 05:38 AM
Kevin
SixtyAte's Avatar
Re: all gauges don't work
Check the connectors at the dash with a test light to insure power there. You may want to try setting up a temporary ground and see if they now work. A bad ground or a tiny crack in the circuit board can result in your problem.
Kev
SixtyAte is offline
post #3 of 3 (permalink) Old Jan 1st, 07, 08:57 AM Thread Starter
I haven't checked the connections from the harness side, thanks kevin! I'll give that a shot.
No Turn signals but hazards work scalise Electrical & Wiring 7 Oct 30th, 06 11:23 AM
autometer gauges fred skinner Interiors 3 May 26th, 05 05:57 PM
Michigan restoration shop suggestions 69ss350camaro Body Shop 3 Jan 20th, 05 06:29 AM
Body shop referral in CT ponjohn Body Shop 5 Oct 19th, 03 06:24 AM
i need my gauges to work ss283 Electrical & Wiring 1 Apr 30th, 02 06:37 PM
