Temp gauge / new Alternator - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 30th, 06, 05:32 PM Thread Starter
I'm having a weird problem with my temp gauge after installing a new alternator.
The temp seems to fluctuate rapidly... a few high RPM and the the temp goes to near hot, idle a few minutes and it goes back to normal, you can watch it move.
Unhook the alternator and the gauge acts normal, might slightly fluctuate but nowhere near the amount it does with the alternator working...
It's a '68 with factory console gauges, with the temp wire going into the harness on the drivers side, along with the alternator wires, all very near the alternator.
Any Ideas?
thanks,
joe
Turbo_Jet is offline
post #2 of 3 (permalink) Old Dec 30th, 06, 07:03 PM
madmax87's Avatar
Re: Temp gauge / new Alternator
Sounds like your temp gauge wiring is getting some noise from the alternator. More than likely, you need a better ground to your console gauges. Did you hook up your ground straps to the engine?
madmax87 is offline
post #3 of 3 (permalink) Old Dec 31st, 06, 04:49 AM Thread Starter
Yep, ground straps are hooked up.
Hmmmm... better ground to the gauges, huh. The gauge does not change instantly with rpm, would noise affect it that way?
thanks,
joe
69 console temp gauge not working garyj Electrical & Wiring 3 Jul 22nd, 06 12:32 AM
67 console temp gauge question Eighttrakz Electrical & Wiring 0 Mar 23rd, 06 03:39 PM
Temp. Gauge denis68 Electrical & Wiring 4 Jul 24th, 05 02:38 PM
Console Temp; Gauge clm69z28 Electrical & Wiring 4 Apr 22nd, 05 07:53 AM
Mechanical Temp Gauge Problem ? Rons68 Troubleshooting 11 Apr 10th, 02 10:25 AM
