mini starter wiring - Team Camaro Tech
post #1 of 4 (permalink) Old Dec 31st, 06, 06:01 AM Thread Starter
mini starter wiring
Ok guys..here is my issue..i installed a allstar mini high torque stater on my 69 camaro. AT first i was a lil confused on three wires to 2, but figured that issue out..the one that came from the original "s" terminal goes to the new selninoid connection. Here is where i am confused, when i test light the original "s" and "R" terminals i am getting constant voltage from the "R"-bigger wire and no voltage from the "s" terminal. I recently have installed a msd 6-a box and msd 85551 billet dist. When i check my accel super coil i am not showing voltage here either. Although, i did run a live wire directly from the alternator to selinoid and the car started right up. Does anyone have any tips?
Wiring is not my specialty!!!!
dads camaro is offline
post #2 of 4 (permalink) Old Dec 31st, 06, 06:09 AM
Re: mini starter wiring
Like holy cow! Guess spamming the forums is your specialty tho?
Multiple posts is not required or desired here. One thread per question will suffice.
post #3 of 4 (permalink) Old Dec 31st, 06, 06:22 AM
ok, now that the ball is rolling on the house cleaning...
The original wiring used a large purple wire to the "S" terminal, which is closest to the engine on the starter. This is the wire that makes the starter engage and start the car, and it is the wire you should attach to the new mini-starter.
The original wiring also had a yellow wire which attached to the outer terminal on the starter and ran to the positive terminal on the coil. You no longer need this wire, and should remove it or disconnect both ends and tape it up.
If the engine doesn't crank when you turn the key, there is a problem somewhere on that big purple wire. Note that the ignition system (distributor, coil, msd box) has NOTHING to do with "will the starter turn the engine over?"
A likely problem with the purple wire is the neutral safety switch. The linkage that operates it is often disconnected when headers are put on a 69. You might even try grabbing the base of the steering column, just out of the dash, and turning it counter clockwise, the turn the key and see if she cranks.
Once you have her cranking over, does she start and run? This question involves the ignition wiring, the wire from the firewall conector to the pos side of the coil, and from there to the msd box, plus some other wiring that should have been added/changed when the electronic ignition and msd box were added.
One zillion dollar question I really need the answer to to help properly is:
Did the old starter crank the car when you turned the key?
Did the car run before you rpelaced the ignition system?
ok, that's 2 questions.
post #4 of 4 (permalink) Old Dec 31st, 06, 08:34 AM Thread Starter
yes she did run when we run a hot lead from the alternator to the stater after install of new starter and with the old starter. The only thing that i can think is when we took the old starter out there might have been a disconnect somewhere when the strter dropped down durin takeout.
Mini Starter wiring Meanchicken Engine 5 Jun 14th, 06 09:59 PM
Wiring a mini starter Edsz28 Electrical & Wiring 4 Feb 3rd, 03 04:16 PM
Starter wiring with MSD Connection swinks Electrical & Wiring 2 Feb 2nd, 03 05:39 PM
Starter wiring with MSD Connection swinks Tech 2003 0 Feb 1st, 03 03:06 PM
STARTER WIRING DILEMA mark67ss Electrical & Wiring 7 Apr 16th, 02 05:04 PM
