67 RS Headlight Doors Inop - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 2nd, 07, 03:35 PM Thread Starter
I recently installed a RS Headlight Wiring Kit and the headlight doors will not open. They do not make any sound as if they are attempting to open. I checked the wiring and contacted Painless to confirm I had everything connected properly. I did notice that the old relay bracket has 3 relays and another smaller part mounted to it. This part was wired to one of the relays. I think it is the circuit breaker. Anyhow, the painless instructions did not mention including this part into the new wiring kit. I know my headlights worked fine before and I can't see how both motors would have burnt out. Please advise.
P.S. Sorry I am unfamiliar with the technical names for these parts. I am fairly new at working on cars.
Maya is offline
post #2 of 6 (permalink) Old Jan 2nd, 07, 05:04 PM
Re: 67 RS Headlight Doors Inop
You are correct, that is a little circuit breaker next to the relays and it is required for the RS system to work as it feeds power to the whole system straight from the horn relay. You should have a red wire from the horn relay going to the circuit breaker and a orange wire from the circuit breaker to the relay #1. Check out my 67 RS help page here:
http://www.retro-electro.net/FAQ.html
Feel free to call (before 9 PM EST) if you need further help.
Marktat is offline
post #3 of 6 (permalink) Old Jan 2nd, 07, 07:35 PM Thread Starter
Thanks. Since my chassis wiring kit and headlight wiring kit did not come with replacement wiring for any of these parts, I guess I am going to have to do some creative electrical work. Painless huh? Just so I am sure I understand your wiring diagram, I need to run a power wire from my positive battery terminal to the horn relay and splice the circuit breaker into my new relay #1? Sounds good. Thanks again for the quick response. -maya
Maya is offline
post #4 of 6 (permalink) Old Jan 2nd, 07, 08:16 PM
Christropher
Mark and his company are great. If you ever need to replace those motors and/or relays, give him a call. btw, next time ya need something for the Camaro, do a search here or ask, we would have told you 2 other companies that sell wiring harnesses that are 50x better than the one you got and would have been plug and play for your application. American Autowire is one, M&H is the other. Painless is anything but.
Christropher
...in pieces still.
clwilcox33 is offline
post #5 of 6 (permalink) Old Jan 3rd, 07, 05:46 AM
Thanks Chris.
There should be a main feed from the junction behind the battery to the horn relay. If so, just add the red wire from the horn relay to the RS circuit breaker ands see what happens.
Marktat is offline
post #6 of 6 (permalink) Old Jan 3rd, 07, 11:11 PM
David Pozzi
davidpozzi's Avatar
The only thing I've had to replace on my 67 RS was the circuit breaker. I think after time the points inside get corroded or worn.
davidpozzi is offline
67 RS Headlight Issues!!! jay'srs/ss Camaro Tech 7 Sep 23rd, 05 12:19 PM
69 RS/SS HEADLIGHT DOORS mark67ss Body Shop 3 Sep 2nd, 03 11:47 AM
headlight doors stuck open Chris396 Tech 2000 3 Apr 16th, 01 07:10 AM
67 HEADLIGHT DOORS WON'T CLOSE David Efford Tech 2000 6 Feb 12th, 01 01:45 AM
68 RS Headlight doors partially working Robert Stacho Tech 2000 6 Dec 9th, 00 06:11 AM
