1992 turn signal lever replacement - Team Camaro Tech
post #1 of 1 (permalink) Old Jan 3rd, 07, 06:51 PM Thread Starter
Aside from removing the fuse and disconnecting the connector to the airbag, is there anything else I need to do prior to removing the steering wheel? The lever does not make contact, so the bright lights are inop.
Or should I just leave this to an expert?
Thanks - (helping out my son with`one of his 3 toys)
D
JEREMYS DAD is offline
69 Camaro Turn Signal Cancelling Cam billscamaros Brakes, Suspension & Steering 2 Mar 20th, 06 06:00 PM
Help with 68 Turn Signal Mechanism sallman Camaro Tech 2 Aug 22nd, 05 08:42 PM
Turn Signal Lever rando Interiors 1 Jun 1st, 04 05:18 PM
67 RS Turn Signal replacement sudo1a67ss350 Electrical & Wiring 4 Mar 4th, 03 03:28 PM
Turn Signal Switch Replacement... 18436527 Electrical & Wiring 2 Feb 2nd, 02 02:05 PM
