camaro has no power but battery is fine - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 4th, 07, 06:04 AM Thread Starter
Hi I have a 69 camaro that won't get any power. I took the car out to burn most of the gas and go get some oil for my other car so stopped at pepboys. When I came back out and went to start like the everything got power but just died like in a second. Reminded me of like a power surge. I was wondering if you guys could help me figure like where to start to look for the problem. When I pull the knob out for the headlights the get no power,the dash has no power,no ignition,nothing has power other than the radio I tested the battery so I know its not that. Any help would really be appreciated.
my69cam327 is offline
post #2 of 6 (permalink) Old Jan 4th, 07, 06:33 AM
Doug
thedugan's Avatar
Send a message via Yahoo to thedugan
Re: camaro has no power but battery is fine
Your Radio has power but nothing else?
-Doug
68 RS/SS Conv
67 Coupe
thedugan is offline
post #3 of 6 (permalink) Old Jan 4th, 07, 07:10 AM
BonzoHansen's Avatar
Sounds like a fusible link might have given up.
TC Member #13
BonzoHansen is offline
post #4 of 6 (permalink) Old Jan 4th, 07, 11:56 AM
madmax87's Avatar
Like Bonzo said, check the wire going from the positive side of battery to the junction connector behind the battery on the radiator support.. There sometimes is a fusible link in it. Quick test would be to run another piece of wire from pos battery post to the junction block and see if your power comes back on. If ok, try wiggling wires on bulkhead under the brake master cylinder. Also check your main ground cable coming off your battery.
madmax87 is offline
post #5 of 6 (permalink) Old Jan 4th, 07, 12:35 PM
Also check the fusible link at the horn relay, it supplies all power to the dash area, see pic
Greg U
undee72Z is offline
post #6 of 6 (permalink) Old Jan 4th, 07, 03:45 PM Thread Starter
Thanks guys yeah the weird thing is the radio is the only thing that has power but this car has had electical problems since I bought it but I pretty much got everything working good and now this. I'll check all that stuff out.
68 Camaro Manual and 84 Monte Carlo SS Power Swap camaro_fever68 Brakes, Suspension & Steering 0 Nov 7th, 06 06:17 AM
MAILBAG: Readers give reactions on Camaro OverAnxious Fifth Generation 0 May 18th, 06 07:07 AM
67 camaro power windows tonyvol Restoration Corner 1 Aug 1st, 05 01:47 PM
2004 SuperCar Reunion Labor Day weekend HawaiianCamaro Team Camaro Cruiz-Ins 1 Aug 25th, 04 08:51 PM
