buss bar - Team Camaro Tech
post #1 of 10 (permalink) Old Jan 5th, 07, 04:22 PM Thread Starter
buss bar
I would like to wire in some gauge lights. My plan was to bring 12 volts to a single point and split off from there with individual wires to individual guages.
So I bought what I thought was a buss bar (is that what you call it?). I wanted something that I could connect 12 volt 14 or 12 gauge wire to, that would then 'distribute' the voltage to other places that I connect there.
What do you all recommend for this? And what should I ask for at the auto parts store?
I don't really want to do this with wire nuts and electrical tape.
mkpatrick is offline
post #2 of 10 (permalink) Old Jan 5th, 07, 04:29 PM
Re: buss bar
Mike, the easiest way to do this is to daisy chain the terminals from one guage to the next. Just put 2 wires in each terminal before you crimp and solder it, except the last one of course.
It should look kinda like a string of christmas lights!
post #3 of 10 (permalink) Old Jan 5th, 07, 04:42 PM Thread Starter
Re: buss bar
I have two wires coming out of each gauge. I can't tell which wire is for hot and which one for ground.
But the wires from the gauges disappear up inside them and I can't really use terminals. This is why I wanted to bring them to a terminal block and distribute 12V to each that way, rather than using wire nuts.
Its the part that I'm looking for. There has to be come aftermarket product for this.
Do you know what that might be?
post #4 of 10 (permalink) Old Jan 5th, 07, 07:09 PM
Re: buss bar
What kind of gauges (make/model) are they ?. If you have two wires coming out of each gauge and you can't tell which one is for hot and which for ground you need to find this out unless they are for the lighting portion of the gauge. Guessing at wiring could cause damage !. If they are the lighting wires for the gauge and it's a regular style filament style bulb then polarity will not matter however if it is an LED type lighting setup then polarity will be a factor.
Most lighted gauges will have a sending unit connection, an ignition power connection, a lighting connection and possibly one or two grounds, or they could be self grounding to where the housings need to be grounded for them to work.
Get the gauge make/model info first or pictures of what you have.
SOA-Nova is online now
post #5 of 10 (permalink) Old Jan 14th, 07, 11:40 PM
Re: buss bar
Is this what you are looking for?
http://www.madelectrical.com/catalog/cn-1.shtml
king67rsss is offline
post #6 of 10 (permalink) Old Jan 15th, 07, 09:38 AM
madmax87's Avatar
Re: buss bar
I did alot of my AutoMeter gauge work like this. They now have a wire harness for them. Look for terminal block if this is what your talking about. You can add jumper tags across the terminals to tie them together like on the bottom right.
madmax87 is offline
post #7 of 10 (permalink) Old Jan 15th, 07, 10:55 AM
Doug
thedugan's Avatar
Send a message via Yahoo to thedugan
Re: buss bar
Damn that's a clean job. Nice
-Doug
68 RS/SS Conv
67 Coupe
thedugan is offline
post #8 of 10 (permalink) Old Jan 15th, 07, 03:49 PM Thread Starter
Re: buss bar
Where would I get those jumper tags?
post #9 of 10 (permalink) Old Jan 15th, 07, 03:50 PM Thread Starter
Re: buss bar
I like that. I could use that too....
post #10 of 10 (permalink) Old Jan 15th, 07, 03:58 PM
madmax87's Avatar
Re: buss bar
Radio Shack sells the tags but not that beefy of a block. My buddy works for the city and parts out the electical boxes. If you decide to go this way, let me know, I may have one left.
Actually, I take that back. Those terminal blocks I did get at Radio Shack. The one I have in the engine compartments were from the city.
madmax87 is offline
horn relay buss bar 69rszee Electrical & Wiring 2 Jun 27th, 06 03:16 PM
Addco Sway Bar Questions (1-1/8") MrDanB Brakes, Suspension & Steering 19 May 10th, 06 08:09 PM
Sway Bar install tip robbm Brakes, Suspension & Steering 1 Mar 27th, 06 08:48 AM
Sway bar question for Mr Pozzi robbm Brakes, Suspension & Steering 11 Jan 25th, 06 04:55 AM
Hotchkis sway bar 400bird Brakes, Suspension & Steering 3 Jul 10th, 05 01:43 AM
