69 front kick panel lights? - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 6th, 07, 07:10 AM Thread Starter
Send a message via AIM to ddonzella Send a message via Yahoo to ddonzella
I bought a new kick panel light circuit for my 69. the original appears to be gone. Where does this two prong connector hook into??? One white wire one orange. I don't see a male double connector under the dash or kick panal area! I have the orange and white wire in the desending harness going to the floor board but no connectors are apparently there
ddonzella is offline
post #2 of 4 (permalink) Old Jan 6th, 07, 07:30 AM
Re: 69 front kick panel lights?
It sounds like you are describing the underdash courtesy lights used only on verts?
The connector is up and perhaps behind the drivers side kick panel. Reach over the ebrake assy and you should find it.
If you don't have a vert, I don't know if this plug is used on the coupes, it should exist though.
post #3 of 4 (permalink) Old Jan 6th, 07, 09:54 AM
Charles
the underdash courtesy lights were standard on all verts (no dome light) but were also an option on coupes. without seeing a pic there are two places that connector could go, one is the door jamb switch itself on the drivers side or the other would be where it hooks into the intermediate harness that runs under the carpet gaurd along the drivers door sill. the intermediate harness for courtesy lights is different on cars with that option as there is a pigtail for the lights, non courtesy light cars don't have that pigtail. if your car didn't originally have courtesy lights your intermediate harness probably doesn't have the proper pigtail for them. you can get that harness from any major resto house. the intermediate harness connects the fuse block to the rear lights, dome light, gas tank, and rear defrost if you've got one of those.
BELIEVE IN YOUR DREAMS
1969 SS X55 NOR added RS all NOS sheetmetal, ground up resto. 24 year project and dream. optioned out the wazoo. in one thousand pieces, and coming together finally.
Run269 is offline
post #4 of 4 (permalink) Old Jan 6th, 07, 02:03 PM Thread Starter
Thanks guys!!
trick to getting out 69 front parking lights? Cpz28 Body Shop 2 Sep 19th, 06 04:10 AM
69 rear turning lights & headlights? Frost Green 69 Electrical & Wiring 1 Oct 10th, 05 06:55 AM
Deluxe Kick Panel Leak Seakane Interiors 19 Jun 11th, 05 06:51 PM
Door adjustment jsouthco68camaro Body Shop 9 Mar 7th, 05 05:46 AM
Trunk Lid Fit Problem RPOL72 Body Shop 8 Aug 27th, 03 01:45 AM
