OER Tach, Delco-Remy distributor - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 7th, 07, 03:25 PM Thread Starter
I don't see this exact problem anywhere. The tach never gets off zero. I checked and am getting 12+ volts across the pink wires and ground. I am getting 12+ volts across the brown wire and ground. The brown wire is plugged into the terminal labeled tach on the distributor/built-in coil. I have a delco 1104067 distributor.
Do I need a tach filter? Where can I get one?
Chuck Sodowsky
chucksodowsky is offline
post #2 of 8 (permalink) Old Jan 7th, 07, 04:14 PM
Re: OER Tach, Delco-Remy distributor
Do a search on "tach filter".
go2fast is offline
post #3 of 8 (permalink) Old Jan 7th, 07, 08:02 PM
look in the basics sticky in electrical.
post #4 of 8 (permalink) Old Jan 7th, 07, 09:48 PM
madmax87's Avatar
Do you have power going to your tach besides the signal wire? 12V on brown wire doesn't sound correct. Sure your on correct lug.
madmax87 is offline
post #5 of 8 (permalink) Old Jan 8th, 07, 07:37 AM Thread Starter
There are 2 lugs. One says bat which has a hot wire going to it. Ones says tach which has the brown wire going to the tach.
post #6 of 8 (permalink) Old Jan 8th, 07, 07:53 AM
madmax87's Avatar
Chuck, is it a factory tach? New install or has been there awhile.
madmax87 is offline
post #7 of 8 (permalink) Old Jan 8th, 07, 07:56 AM
There should be a ground terminal also if I'm not mistaken.
Dave, 69 Coupe, 383, Q-jet, Thorley headers, 350 turbo, P.S., P.B. console gauges, Tilt wheel, Black with green pearl paint, Black and White Houndstooth interior.
Black69 is offline
post #8 of 8 (permalink) Old Jan 9th, 07, 05:46 AM Thread Starter
This is a brand new tach from OER. There is also a ground wire that goes to the tach. I have tested it as well and have a good ground.
delco remy 1111016 distributor ?? nikkisdad Engine 5 Aug 14th, 07 06:32 PM
69 camaro tach issue with hei - OER CAMARO GUY Electrical & Wiring 6 Aug 24th, 05 08:36 PM
Repo tach and HEI distributor dbackse350 Interiors 3 May 14th, 05 08:15 PM
New OER Dash Tach WORKS with MSD! Brian Lewis Electrical & Wiring 2 May 6th, 05 11:52 AM
Delco Remy Capacitor Discharge Dan Palchanes Tech 2001 1 Nov 18th, 01 06:45 PM
