Issue: Autometer Sending Unit not mating to Lokar Speedometer Cable - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 11th, 07, 06:08 PM Thread Starter
Hi Guys ...
I have a following Autometer Speedometer: ATM-3988 http://store.summitracing.com/partde...2D3988&FROM=MG
Autometer recommended the ATM-5291 Sending Unit for this Speedometer ... http://store.summitracing.com/partde...5&autoview=sku
If you click on the suggested parts to work with the sending unit, Summit recommends this Lokar Speedometer cable ... LOK-SP-1500U ... http://store.summitracing.com/partde...t=LOK-SP-1500U
Now, here's my problem ... the end of the cable that connects to the sending unit is a female type fitting and so is the end of the sending unit that connects to the cable ...
Here's a pic that I took to show what I'm referring to ... (it's a little blury, but you'll get the idea) http://home.earthlink.net/~timandste...endingunit.jpg
Is this common ... do I just get an adapter?
Thanks,
TIM
'95 383 CAMARO Z28 - C.A.M. BUILT/TUNED
405 RWHP/428 RWTQ (SAE DynoJet)
'99 CORVETTE
'68 CAMARO - 383+D1SC, Orion Silver
Tim_in_NC is offline
post #2 of 6 (permalink) Old Jan 11th, 07, 10:53 PM
Russ
Re: Issue: Autometer Sending Unit not mating to Lokar Speedometer Cable
Tim,,,
maybe I'm missing something, but..... isn't the Autometer Speedo and sensor both electronic units? The Lokar cable appears to be for a mechanical speedometer. I wouldn't think you'd have anything hooked to that sensor on the tranny other than wiring up to the speedo. I believe that sender has a connection for a pass-through for cruise control if used, but other than that should just have wiring to it. Looks like mechanical cable for an electronic speedo unless I'm missing something.
Blown 69 RS Camaro
383 Small Block
Dyno: 578 Horse - 595 LB/Torque
Blown69RS is offline
post #3 of 6 (permalink) Old Jan 12th, 07, 12:19 AM
Bryan
You shouldn't need a cable with that speedo if it's electronic. I've got the same sending unit on another Autometer electronic speedometer. All you need to hook up to the sending unit is three wires: 12V positive, ground, and an output wire to go from the sending unit to the speedo.
1968 Camaro, 383 with Dart Pro 1 aluminum heads and roller cam, Holley Sniper EFI with Dual Sync distributor, Muncie M21 4-speed transmission, 3.73 12-bolt Eaton posi differential.
Bry68 is offline
post #4 of 6 (permalink) Old Jan 12th, 07, 04:45 AM Thread Starter
Thanks for the help guys ... I'm still new to several of these electronic doohickeys ... It would have helped me if Summit didn't recommend this cable in conjunction with the sending unit/speedo ...
Oh well ... thanks a bunch guys for straightening me out!
I've got another question ... How does this sending unit determine my speed, if I'm only connecting power, ground, and the sending unit to the speedometer ... I need something to connect my tranny to this autometer sender, right ... anyone got a part number ... It's a 200-4R tranny ...
Also, I have the American Autowire Classic update wiring kit as well as the American Autowire Covan Classic Gauge connection kit ... seen here: http://store.summitracing.com/partde...5&autoview=sku
'99 CORVETTE
post #5 of 6 (permalink) Old Jan 12th, 07, 05:11 AM Thread Starter
Ok, this is making sense now ...
I just plug the sending unit directly into the transmission where the cable would have connected ... then go from there ...
I'll be sending back the Lokar ...
thanks again,
TIM
'99 CORVETTE
post #6 of 6 (permalink) Old Jan 12th, 07, 10:18 AM
Russ
yep, that's all you need to do. Once that is done, there is a calibration procedure to follow with the speedo. The speedo counts the pulses from the sensor over a specific distance, and then calculates speed... all the procedure should be in the instructions. Not much to it.
Blown 69 RS Camaro
383 Small Block
What color wire from sending unit Kevinator Electrical & Wiring 4 Aug 29th, 06 07:05 PM
Covans Sending Unit w/ Autometer Speedo Question Blown69RS Electrical & Wiring 3 Jul 20th, 06 07:48 AM
Which speedometer cable? 67killerb Transmission & Driveline 1 Apr 11th, 03 11:14 PM
Speedo cable for Autometer soda Electrical & Wiring 3 Feb 13th, 03 05:34 PM
Speedometer Cable Breaking Cameron Engine 9 Sep 19th, 02 01:15 PM
