Custom Engine harness availability - Team Camaro Tech
post #1 of 10 (permalink) Old Jan 12th, 07, 12:19 PM Thread Starter
stevo camaro's Avatar
I've read several archives on 1 wire, or 3 wire altenator conversions to eliminate external voltage regulator.
My stock harness is junk, (speaker wire spliced in & numerous wires fried or cut.)
Question is, is there a engine harness available that will plug into stock fuse box, but without the uneeded external regulater wiring?
Or, should I just go with a new stock harness & cut the wires off to the regulater? (I'm leaning this way.)
Battery is in the trunk, Moroso bulkhead fitting at the firewall being used.
Will be running electric fuel pump & electric fans at radiator, will have a 500 watt stereo. (at least)
And yes, I'm running proper size & type cable for battery.
Wiring is not my cup of tea.
67 RS 327, 4-speed, posi, done.
67 Modified, 454, TH-400, posi, under construction.
67 SS 396, 4-speed, basket case.
72 RS, sitting, partially done.
55 210 post, 2 door, 327 4-speed runs good.
55 2 door post, gasser project
69 Cadillac ElDorado
69 4x4 suburban
59 ElCamino
Some mornings, it's just not worth chewing thru the leather straps"
stevo camaro is offline
post #2 of 10 (permalink) Old Jan 12th, 07, 12:36 PM
DjD
DjD's Avatar
Re: Custom Engine harness availability
Hey Steve - there was a harness on ebay that wasn't as expensive as a finished factory style harness or a custom painless harness. It comes bare and with all the wires for a stock application. You install the connectors they supply and wrap it yourself. Sounds like it might be the way to go since you could spare out what you don't want to use...
I'll look for what I saw and link it if I can find it...
...Dennis
DjD is offline
post #3 of 10 (permalink) Old Jan 12th, 07, 12:57 PM
I believe American Autowire's classic update series will have the product you want, click the sponsor link to check.
post #4 of 10 (permalink) Old Jan 12th, 07, 01:02 PM
American Autowire and M&H will sell you factory harness modded for internally regulated alternator, HEI ect...
http://www.americanautowire.com/
http://www.wiringharness.com/
Greg U
undee72Z is offline
post #5 of 10 (permalink) Old Jan 12th, 07, 02:10 PM Thread Starter
Thanks guy's, I'll be looking at the links.
69 4x4 suburban
59 ElCamino
post #6 of 10 (permalink) Old Jan 12th, 07, 03:35 PM
Rod
I think this is the one your looking for http://cgi.ebay.com/ebaymotors/EZ-WI...rdZ1QQtcZphoto
It is a nice harness from what I read about it, but it does not bolt directly into the factory location as it is a universal harness.
Rod
69 Camaro with LS2/4l70e
Rocketrod is offline
post #7 of 10 (permalink) Old Jan 12th, 07, 04:02 PM
Stevo -
Definitely give AAW a call or check out their site. I have their classic update kti for my 69, and it has the wiring for electric fuel pump, fans, engine computer, power seats, power windows, etc, in addition to all the factory circuits (okay, it didn't have the key minder buzzer ). All the wires are top quality (nice fat ones for things like the electric fuel pump and other high amp circuits), and their customer service and tech support are top notch. It's around $450 for the kit, but that is all new wiring front to rear.
Eric
Eric Kammerer is offline
post #8 of 10 (permalink) Old Jan 12th, 07, 06:04 PM Thread Starter
I just sent AAW a request for what I need. Probably won't hear anything till next week.
I told them what I had, & what I need, so I'll see what they can do.
69 4x4 suburban
59 ElCamino
post #9 of 10 (permalink) Old Jan 12th, 07, 07:53 PM
Frank
And you can save money on your AA stuff at GPSuperStore.com in the active group Purchase for American Autowire.
Just get your part number, then try us for the best price
ProdigyCustoms is offline
post #10 of 10 (permalink) Old Jan 12th, 07, 07:59 PM Thread Starter
Thanks Frank. I'll do that.
69 4x4 suburban
59 ElCamino
engine wire harness ext. green z Camaro Tech 0 Dec 2nd, 06 03:12 PM
Engine Harness Question ironhorse78247 Electrical & Wiring 8 Nov 17th, 06 09:16 AM
New Wiring Harnesses scottl2 Electrical & Wiring 5 May 19th, 06 09:49 AM
New Engine Harness SEK Z28 Electrical & Wiring 1 Feb 22nd, 02 10:25 AM
Another engine harness ? tl757 Electrical & Wiring 4 Feb 1st, 02 03:25 PM
