turn signal switch - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 15th, 07, 05:54 PM Thread Starter
turn signal switch
I am in the process of replacing the turn signal switch in the steering column in my '68 coupe which appears to have initially come with a column shifter and currently has a shifter on the floor. My question is: what turn signal switch should I install (I see that 2 types are available depending on where the shifter is located). Thanks in advance for any advice.
matthewdumont is offline
post #2 of 3 (permalink) Old Jan 16th, 07, 02:45 AM
Kevin
SixtyAte's Avatar
Re: turn signal switch
Matt...
If your car came with a shift column and you still have it in there, use the one for what you have. Because you now have the shift on the floor does not change how the part fits in the column.
Kev
SixtyAte is offline
post #3 of 3 (permalink) Old Jan 16th, 07, 10:48 AM Thread Starter
Thanks.
Stop lights and turn signal ssvette Electrical & Wiring 3 Feb 14th, 12 04:02 PM
Turn Signal Dash Lights - What now? HELP! chedderboy Electrical & Wiring 9 Dec 26th, 05 07:59 PM
69 Turn Signal Switch Harness Adapter 69-er Electrical & Wiring 1 Aug 9th, 05 06:19 PM
light switch and turn signal roho29 Electrical & Wiring 1 Mar 30th, 04 06:15 AM
turn signal, brake, parking lights no1dc1983 Electrical & Wiring 11 Jul 16th, 00 04:34 AM
