Headlight upgrade - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 15th, 07, 07:31 PM Thread Starter
Dan
Headlight upgrade
I am closing in on the finish line with my 69 project. I want to upgrade the headlights to give a more modern custom look. I looked at Zoops lights (summit racing has them) and was wondering if anyone else was using them? If not, what do you recommend that are more for a custom look? I am going to be adding relays and circuit breakers so I'm not concerned about the lamps drawing too much power. Thanks in advance.
Carbo is offline
post #2 of 4 (permalink) Old Jan 16th, 07, 04:36 PM Thread Starter
Dan
Re: Headlight upgrade
Here is the headlight I was referring too. Has anyone used this one or recommend any others?
http://store.summitracing.com/partde...5&autoview=sku
Carbo is offline
post #3 of 4 (permalink) Old Jan 16th, 07, 06:23 PM
That BLUE DOT is going to make it illegal on the streets. You can get the same setup but without the blue center dot for $5.99 on Ebay! (yes thats not a misprint), example is auction 300069719892
Then just don't install the blue light and use some H4 Sylvania Silverstar
Or just buy a new set of H6024ST Sylvania SilverStars, they are $19.95ea at autobarn.com for example, same as what an H4ST would cost you but you won't need the enclosures.
and
Brian Lewis is offline
post #4 of 4 (permalink) Old Jan 16th, 07, 07:26 PM Thread Starter
Dan
Thanks Brian. I forgot to check on ebay. Looks like there are other choices as well for about the same price. Thanks for the info.
Carbo is offline
Headlight Upgrade Options for a 1st Gen Camaro jay'srs/ss Camaro Tech 45 Mar 16th, 14 12:21 AM
67 rs-ignition removal/tip on headlight wiring 67RS383 Electrical & Wiring 3 Apr 3rd, 10 06:17 AM
Headlight relays questions.... whytry Electrical & Wiring 13 Feb 16th, 06 08:34 AM
67 RS headlight motor armature needed Mandra Restoration Corner 0 Jul 11th, 05 08:56 AM
RS headlight relay upgrade, but not working right Eighttrakz Electrical & Wiring 7 Jul 3rd, 05 09:39 AM
