headlights on - gas gauge = empty - Team Camaro Tech
post #1 of 13 (permalink) Old Jan 16th, 07, 06:41 PM Thread Starter
Strick
When I turn my head lights on my gas gauge goes to empty (regardless of the amount of fuel in the tank). Also, my dash lights as so dim they are nearly non existent.
Any ideas?
Oh, I bought the car this way. I have yet to troubleshoot it. I thought I might discover someone here who has had a similar problem. Everything in the car is stock, except for an aftermarket radio.
Strick
Strick is offline
post #2 of 13 (permalink) Old Jan 16th, 07, 07:47 PM
Steps
Re: headlights on - gas gauge = empty
Go thru and check all your Earths (grounds) Bad earths (rather than no earths)can cause weid things to happen because of the resistance across the bad connection
Steptoe is offline
post #3 of 13 (permalink) Old Jan 16th, 07, 07:52 PM
click's Avatar
JimM has 2 excellent stickies at the top of this section with reading about finding the issues with the old cars. Usually grounds are the issue but read thru those posts up above, I bet you find your problem and answer.
click is offline
post #4 of 13 (permalink) Old Jan 16th, 07, 08:44 PM
make sure the top center screw in the dash cluster is there, that is the ground for the dash lights and fuel guage. If that doesn't help, you might reach up there and see iif you can attach a short peice of wire with a ring terminal to one of the quarter inch screws that hold the back of the instrument cluster together, then ground the other end of the wire.
post #5 of 13 (permalink) Old Jan 16th, 07, 08:45 PM
this will fix your problem 100%. Good luck.
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #6 of 13 (permalink) Old Jan 16th, 07, 09:59 PM
Harley
wiskeesour's Avatar
definately a bad ground.....good luck. My interiors didnt even work. had a bad connection at the fuse, so while I was at it, I just took a wire brush to all the grounds.
Headlights are pulling the juice away from your gas tank guage because its smaller resistance across the headlights than it is across the resistor in the tank. JM.02
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #7 of 13 (permalink) Old Jan 17th, 07, 07:31 AM Thread Starter
Strick
Thanks guys, I will give it a try and post back my findings!
Strick
Strick is offline
post #8 of 13 (permalink) Old Jan 17th, 07, 12:47 PM Thread Starter
Strick
Is this screw you are mentioning visible from the outside, or is it inside. What I am trying to say is, if I am sitting in the driver's seat can I see it?
Thanks!
Strick
Strick is offline
post #9 of 13 (permalink) Old Jan 17th, 07, 12:58 PM
You might not see it, but you can feel it. It is on the outside, just above the high beam indicator
post #10 of 13 (permalink) Old Jan 17th, 07, 12:59 PM
You should be able to see the screw. It's at the top of the gauge cluster in the center, above the steering column between the two big gauges (speedo and tach or gas).
The ground strap is behind the dash and will require you to loosen the column if you need to remove the gauge cluster.
eville is offline
post #11 of 13 (permalink) Old Jul 5th, 07, 06:20 PM Thread Starter
Strick
Well, I am now completely rebuilding the suspension and putting in the new motor (if it will cool off 106 yesterday, 108 today). I found that the battery was grounded to the block, the firewall was grounded to the (sub)frame, but the ground wire from the motor to the firewall had broken and was not attached. Do you think this is my problem?
I tried the R&R of the dash screw (no rust) and that did not help.
Strick
Strick is offline
post #12 of 13 (permalink) Old Jul 5th, 07, 09:09 PM
Harley
wiskeesour's Avatar
oof. Im not sure that would have that specific problem Strick. Keep going and let us know as you go what you find...
AE2
Thanks Chief.
post #13 of 13 (permalink) Old Sep 17th, 07, 06:56 PM Thread Starter
Strick
I wanted to throw out thanks and kudos to Harley, Steve and my man JimM (and all others). The advice they gave about the bad ground on the dash cluster was 100% correct. I had to replace my ignition switch tonight, so I finally go around to properly grounding the dash. I took out one of the cluster 1/4 drive screws (on the back of the fuel gauge) and grounded it to the lower framework of the dash. Viola' my fuel gauge remains constant with lights on or off. Before when I turned the lights on the fuel gauge would drop to empty or below, the turn signal (dash) lights (both) would stay on dimly, and the dash lights would not work. All of that is in the past!
Thanks again!
Strick
Strick is offline
Lights on..gas gauge off... thorpe67RS Electrical & Wiring 5 Sep 28th, 06 06:32 AM
Gas Tank, Gauge, Sending Unit WTF? BPOS Troubleshooting 8 Jul 12th, 06 03:44 PM
Gas gauge Charles Brown Troubleshooting 3 Dec 22nd, 05 08:45 PM
Console Gas Gauge dirkey Electrical & Wiring 2 Apr 21st, 05 06:46 PM
fuel gauge always reads empty?? denverRS/SS Electrical & Wiring 8 Jun 11th, 01 04:27 PM
