Wiring HEI distributor - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 18th, 07, 01:03 PM Thread Starter
Ive asked this question before but still dont under stand: I had a flooded car that I had to rewire. Some wires in the fuse box stay hot but I cant find one that goes hot when I turn the ignition switch. I hooked up a universal switch with the hot wire going to the Hei; it works but the wire gets hot to touch. Is there something that goes between to cut down the juice? or can you just go hot wire directly to Hei? what about a relay, fusible link or?
musky is offline
post #2 of 5 (permalink) Old Jan 18th, 07, 01:19 PM
Re: Wiring HEI distributor
On a first or second generation Camaro there should be a 1/4" male spade terminal on the fuseblock marked IGN. Just run a piece of 12 gauge wire with a 1/4" female spade on each end from there to your HEI.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 5 (permalink) Old Jan 18th, 07, 01:43 PM Thread Starter
Yes I know about wire to fusebox but I had to wire this whole car because it got floode and when I turn the key I dont have any hot coming from the fuse box. I my own ignition switch in with hot coming directly from battery to switch and then out to HEI when key is turned on. It would be like going straight from battery to HEi will this burn something out?
musky is offline
post #4 of 5 (permalink) Old Jan 18th, 07, 03:37 PM
Craig
Brackneyc's Avatar
Could burn the car to the ground in a fire.
Craig
Now you will see that evil will triumph, because good is dumb.
-Dark Helmet
1967 Camaro
1965 Mustang
2007 Mustang
Brackneyc is offline
post #5 of 5 (permalink) Old Jan 18th, 07, 11:11 PM
Yr of car??? (you shoud add it to your sig) How did you rewire the car? Did you use a replacement harness? Are there some fuses that are never hot? If so the IGN switch may not be feeding the fuse box. Some wires in the fuse box are supposed to stay hot, others are only hot either when the IGN key is on or the in the case of the dash lamps fuse, only when the parking or headlamp switch is on.
Where did you get power from? What size wire did you use? You should have used at least a 12g. Hot wires are usually a short, or using to small of a wire.
No
NO, if you did the HEI would be draining the battery with the car off, unless you add a switch.
As a temporary measure, you can use a relay, get power from the horn relay, add a 20 amp fuse close to horn relay, until you get your problems straighten out. Heres how to wire it using a Bosch relay
30 to horn relay with a inline fuse
87 to HEI bat
86 to horn relay
85 to one side of your universal switch, the other side to ground.
This way power for the HEI doesn't travel through the switch. The switch only turns the relay on & off. Hope this helps.
Greg U
undee72Z is offline
HEI Distributor matto68 Engine 9 Jan 9th, 07 09:07 AM
New HEI distributor, have a few questions before dropping it in Timmo99 Electrical & Wiring 2 Sep 30th, 06 06:11 PM
Interesting (I think, anyway) wiring nightmare: HEI and electric fuel pump. 69454 Electrical & Wiring 6 Aug 23rd, 06 12:51 AM
Small Body HEI Wiring? fishin4info Engine 0 Jun 28th, 06 10:59 AM
HEI Distributor Sixty-Seven rs Engine 2 Oct 1st, 05 01:49 PM
