140 amp alt ? - Team Camaro Tech
post #1 of 11 (permalink) Old Jan 19th, 07, 07:00 AM Thread Starter
Patrick
140 amp alt ?
My alt does not start charging until I rev the engine up at least to 3500 rpm. If I just crank it up and let it idle it won't be charging. Once it starts charging, it will stay charging even at idle. But that's after I rev it up. Is there anything wrong with it?
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #2 of 11 (permalink) Old Jan 19th, 07, 07:06 AM
Re: 140 amp alt ?
Is it a 1-wire setup?
onovakind67 is offline
post #3 of 11 (permalink) Old Jan 19th, 07, 08:41 AM Thread Starter
Patrick
Re: 140 amp alt ?
No it replaced the original one. It has one big 12v wire in back and the two prong plug on top.
383 IS SOLD!
Building a 489BBC
post #4 of 11 (permalink) Old Jan 19th, 07, 08:48 AM
Re: 140 amp alt ?
What's probably happening is that the alternator has to reach a certain speed to use the residual magnetism to bootstrap itself, and once it has the field powered, it will continue to produce power as long as you don't stop it.
Does your 'gen' light come on when you turn on the key? On the stock setup, the current through the 'gen' light is used to flash the field and start the alternator at a lower rpm. Once the field is powered the light has 12v on either side of it and it goes out.
post #5 of 11 (permalink) Old Jan 19th, 07, 10:40 AM
madmax87's Avatar
Re: 140 amp alt ?
Mine does the same thing. No gen light as it is a console car. Had to get it to 4k to excite the field. Found out the little brown/white 24 gauge resistance wire had burnt up at some time (ignition sw to VR). When I got car it had a 1 wire on it. I converted back to stock and ran into this. Check the electrical sticky for wire diagrams.
madmax87 is offline
post #6 of 11 (permalink) Old Jan 19th, 07, 11:36 PM
Re: 140 amp alt ?
you mean any car that has a console has NO idiot light?
that is kind of a stupid design.
my 74 Monte has a stock ammeter (which doesn't work), but it also has a "gen" light.
you don't plan sincerity.
novaderrik is offline
post #7 of 11 (permalink) Old Jan 20th, 07, 01:34 AM
Re: 140 amp alt ?
I just did some work on a 69 SS/RS console car and it had a 'gen' light...
post #8 of 11 (permalink) Old Jan 20th, 07, 02:20 AM
madmax87's Avatar
Re: 140 amp alt ?
Gen light is not hooked up if it is an original console car on a 69. The little plastic lens is there but no electrical connection behind it. Have no idea about a 74 Monte, but I believe speedfreek is talking about a 69 rs/ss.
Here is an earlier posting about this problem and gen light, Jim also confirms no light on console cars. See post #11
https://www.camaros.net/forums/showthread.php?t=85165
madmax87 is offline
post #9 of 11 (permalink) Old Jan 20th, 07, 11:10 AM
Re: 140 amp alt ?
i guess by 74 they figured out that even in cars with gauges, an idiot light is a good idea..
post #10 of 11 (permalink) Old Jan 20th, 07, 12:08 PM
madmax87's Avatar
Re: 140 amp alt ?
Can't be too careful, thats for sure!
madmax87 is offline
post #11 of 11 (permalink) Old Jan 20th, 07, 12:20 PM
Re: 140 amp alt ?
All firstgens, including gauge cars, have a length of resister wire in the dash harness wired in parallel with the gen light, to light off the alternator even if the gen light is burned out, or in the case of a gauge car, there is no gen light. You might check that wire, bet you have the same problem madmax did.
140 amp alt wiring freebird Electrical & Wiring 4 Aug 17th, 06 05:39 PM
AAAHHH! i blew up my monsoon amp sgt0704 Electrical & Wiring 0 Jul 25th, 06 05:34 PM
140 amp alternator upgrade stamatisg1977 Camaro Tech 8 Sep 12th, 05 07:07 AM
1 wire alt question Kwondo1967 Electrical & Wiring 2 May 15th, 05 06:40 PM
Higher output alt? aonghus Electrical & Wiring 1 May 11th, 05 04:13 AM
