67 turn signal dash bulbs - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 21st, 07, 08:28 AM Thread Starter
Jeff
Question 67 turn signal dash bulbs
The right turn signal dash bulb appears to have burned out. What's the best way to get at it? Is removing the cluster the best option?
jlb307 is offline
post #2 of 4 (permalink) Old Jan 21st, 07, 09:11 AM
Re: 67 turn signal dash bulbs
you should be able to reach it. it's a quarter turn twist lock, and should pop right out. Here's a pic of what you're feeling, should help some. Turn indicators are bottom center in each group. pic is 68, but is same.
post #3 of 4 (permalink) Old Jan 22nd, 07, 09:22 AM
Dennnis Giles
Jim, just pulled my 67 cluster the other day it doesn't look like yours.Mine has the printed circuit, no wires. What is that white thing with the OC on it.Have you done mods to it? thanks!
Deny411 is offline
post #4 of 4 (permalink) Old Jan 22nd, 07, 09:30 AM
Mine is somewhat "modified."
I retrofitted a tic toc tach using the original pcb to retain all the idiot lights. The white thing is the back of the tach. Yours will be similar, with the turn signal bulbs bottom center in each gauge and the illumination bulbs the 4 across toward the top.
Correct 67 turn signal lever Lost in the 60's Restoration Corner 2 Jan 17th, 07 07:51 PM
Short in Turn Signal Short Hank's 68 Electrical & Wiring 3 Jan 13th, 07 08:00 AM
Dash Lights-Left Turn Signal cilla6791 Electrical & Wiring 1 Nov 30th, 06 08:55 PM
Hazard and Turn Signal Light Issue 68camrs Electrical & Wiring 2 Jan 5th, 06 12:47 PM
BRAKE lights OUT when USING THE TURN SIGNALS KED67 Electrical & Wiring 5 Jun 26th, 01 03:40 PM
