autometer gauge brightness problems? - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 23rd, 07, 08:07 AM Thread Starter
my 6-led bulbs came from superbrightleds yesterday so I installed them lastnight. the problem is in my water temp and oil pressure gauges they arnt hardly visible. the volt voltmeter is ok but not bright enough. what do you guys think my problem is?
fossilrunner is offline
post #2 of 7 (permalink) Old Jan 23rd, 07, 11:19 AM
Re: autometer gauge brightness problems?
Poor ground
Larger Dave is offline
post #3 of 7 (permalink) Old Jan 24th, 07, 02:44 PM
I could also be due to the pattern of light the LED's put off. Some are very directional and others spread the light out more. I have the same issue in my boat gauges. They look very dim but it is the worst with the smaller gauge faces like you show above.
forttusken is offline
post #4 of 7 (permalink) Old Jan 24th, 07, 03:31 PM
Kevin
SixtyAte's Avatar
It looks like the last to gauge faces are out too far not allowing the light to surround the gauge face. If you look at the first gauge, you see white light around the edge. Try pulling the other into the case further....
Kev
SixtyAte is offline
post #5 of 7 (permalink) Old Jan 24th, 07, 09:50 PM Thread Starter
how can u pull the gauge face in
post #6 of 7 (permalink) Old Jan 24th, 07, 10:48 PM Thread Starter
seams the problem is the two mechanical gauges faces are to close to the glass which doesnt allow enough light to emit through vs the electrical gauge which is pulled back farther. can I fix this some how?
post #7 of 7 (permalink) Old Jan 25th, 07, 02:55 AM
Kevin
SixtyAte's Avatar
Fossil,
It may be best to contact Autometer and see what they advise.
Kev
http://www.autometer.com/
Auto Meter
Test Equipment/OEM Instrumentation
413 W. Elm Street
Sycamore, IL 60178
Test Tel: 866.883.8378
Test Fax: 815.895.6786
OEM Phone: 815.895.8759
OEM Fax: 815.895.6786
SixtyAte is offline
autometer fuel gauge wiring importkiller69ss Electrical & Wiring 10 Jan 31st, 06 05:17 PM
Autometer Electric Oil Gauge Sender pwoolford Engine 3 Jan 28th, 03 04:02 AM
fuel gauge reads over full... mike brown Troubleshooting 10 Aug 4th, 02 08:29 AM
AutoMeter Fuel Gauge Joe G Interiors 5 Jan 9th, 02 07:51 PM
Wiring problems with console fuel gauge Jeff H Tech 2000 1 Nov 15th, 99 04:40 AM
