Ignition bezels - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 29th, 07, 05:57 AM Thread Starter
Ignition bezels
Hi,
I just purchsed a used 67 camaro ignition and shortly after, the inner and outer bezels from NPD. the problem that I have is that the bezels do not go over the part of the ignition that the key inserts into.
Can anyone point me in the right direction for taking the key part out of the switch, and/or email me a diagram or two?????
thanks all!
Cory
cory is offline
post #2 of 5 (permalink) Old Jan 29th, 07, 08:18 AM
Re: Ignition bezels
Do you see a tiny hole in the lock cylinder? You have to put something in that hole (I use a tiny allen wrench)to release the lock from switch.The keys have to be in cylinder and you have to turn them one way or the other to release lock.Hope this helps. Dewayne
d's 68 is offline
post #3 of 5 (permalink) Old Jan 31st, 07, 04:25 AM
Cool Re: Ignition bezels
Yep, put that tiny allen wrench in that hole and turn the ignition to the left and or right?? while slightly pulling and it will seperate from the bezel, then reinstall it in the new receptacle.
bdzee is offline
post #4 of 5 (permalink) Old Jan 31st, 07, 05:48 AM
Re: Ignition bezels
put the key in "accessory" stick something in the hole (I use a straightened out paper clip) then continue turning the key counterclockwise. If you hit the "button" in the hole right, the key will continue to turn till it's near horizontal and you'll be able to pull the cylinder out with the key.
post #5 of 5 (permalink) Old Feb 2nd, 07, 06:45 AM Thread Starter
Re: Ignition bezels
thanks a lot guys, that worked like a charm!!!!!
cory is offline
Car Running....Then lost all power to Ignition! HELP jsabowabo Electrical & Wiring 10 Jul 20th, 06 05:40 PM
Ignition switch bezel KWIK 69 Electrical & Wiring 5 Apr 21st, 06 06:20 AM
Ignition problems tstrobl1 Electrical & Wiring 5 Feb 3rd, 06 03:44 AM
1967 Camaro 350 Ignition wiring question Mean_Gene3 Engine 6 Oct 2nd, 05 11:50 AM
Column ignition help soda Electrical & Wiring 3 Apr 9th, 02 04:07 AM
