Thread jump question? - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 29th, 07, 07:02 AM Thread Starter
Dennis: This was the best descriptor that I could think of for my problem. Or maybe it isn't a problem.
Recently I have noticed a change in the way my computer enters a thread. When I click on the thread I jump right to the middle of the thread. I have to scroll up to the start to get the initial question that was asked. I was wondering if I have inadvertantly set this up as an option or is the Web site doing this? I sometimes don't tune in for a couple of days and I see a thread with multiple replies and I seem to be always scrolling to the top.
If this is normal then I will live with it. It just seemed to have happened recently.
I have owned 3 69 Z/28s: Garnet Red 30,000 mi unrestored.
Glacier Blue, documented Canadian Z
Rallye Green purchased new in 1969
1968 Camaro Coupe L30 275 horse. ]
Stewie is offline
post #2 of 3 (permalink) Old Sep 29th, 07, 08:31 AM
DjD
DjD's Avatar
Re: Thread jump question?
Hi Brian - several things could be happening... When you look at a list of threads each starts out with a that is supposed to take you to the first new post in the thread. Then there is the thread title and it should take you to the very first post unless you have visited the thread before. Then it is supposed to take you to the first new thread as well. Then at the end of the title is this which takes you to the last post in the thread.
I went to a thread I believe I have never clicked on before and hit to see what would happen and it took me to the end of the thread. I had to scroll up to the first post where it should have taken me. On another one I had not opened yet I clicked on the title text. It took me to the first post. There could be some bad logic in the link code or it could be bad cookie information stored on the PC causing this.
Experiment with the 3 links and see if maybe you have just started hitting instead of the text... You can also delete your cookies (you'll have to login again if you do) and see if that helps...
...Dennis
DjD is offline
post #3 of 3 (permalink) Old Sep 29th, 07, 11:55 AM Thread Starter
I tried what you said and sure enough it does work as described. I guess what I am doing is going directly to the thread by hitting the thread title. If I hit the category then hit the thread title it gives me the first posting. If I go directly to the thread it puts me somewhere in the middle. If I hit the arrow it puts me at the last post so I think all is well I am just using it differently. Thanks Dennis.
Stewie is offline
