air condtion question - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 1st, 07, 06:27 PM Thread Starter
Thumbs up air condtion question
my 1969 camro air does not work! should leave it stock or change it over to that nes stuff? also how much does it cost? to change it over? thank camros for ever! I my bought my camaro 24 years ago iam the second owner!
camaro9 is offline
post #2 of 3 (permalink) Old Nov 1st, 07, 07:27 PM
Re: air condtion question
Site discussion is a pretty strange place to post this...
Perhaps more would see it in heating and cooling, or camaro tech?
Pretty much any time you have to fill an A/C system you should convert to r134. It's not a big deal. As for fixing your air, most likely all the freon leaked out, typically thru a hole or bad connection. You'll want to fix that. Bringing it to a qualified tech. I do everything myself, but if I ever put a/c in, I'd do all the nutsnbolts, then bring it to a tech for an evac, leak test and fill.
post #3 of 3 (permalink) Old Nov 2nd, 07, 12:46 AM
parkbrau's Avatar
Why doesnt your air work? Have you properly trouble shot the problem?
If your not familiar with converting your system to 134 then I suggest you take it to your mechanic and ask to have it done by someone that does it for a living.
If you dont want to convert then still take it to your mechanic and ask for it to be leak checked. The systems will bleed through over time, and not running the A/C regularly is not good for it.
Look over in the heating and cooling forum for some tips as well.
parkbrau is offline
