RS section - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 18th, 09, 07:18 AM Thread Starter
Lars
67 Sinner's Avatar
Question RS section
is there an own section for RS-related topics?
(headlights from hell??)
i am trying to convert my standard grille to a rs, but it's not without problems, so i was hoping there would be an own section for these issues..
Lars
Newbie from the North
'67 Camaro 350 / 350 (part RS-clone)
67 Sinner is offline
post #2 of 8 (permalink) Old Jan 18th, 09, 07:42 AM
click's Avatar
Re: RS section
Lars, no separate RS section, just hang in there with your other posts, folks will come along that can help on the conversion issues.
click is offline
post #3 of 8 (permalink) Old Jan 18th, 09, 11:35 AM
Broc
Re: RS section
need the rs fenders.....or cut off the standard and weld in the rs brackets that they sell aftermarket. need new grill and moldings, the headlight buckets, two motors, 4 limit switches, 3 relays, rs harness. search rs parts in ebay. they sell virtually everything for them. 67 are completely different from 68 and 69. similar appearance to 68 but the way they work is different, motors instead of vacuum
1968 Camaro SS 350
--350, muncie 4spd, 12 bolt 3.31 (multi-leaf)
1967 Camaro (plain jane)
--350, muncie 4spd, 12 bolt 3.31 (mono-leaf)
1965 Chevelle Malibu SS 327
--327, powerglide, 12 bolt
The Sleeper 327 is offline
post #4 of 8 (permalink) Old Jan 18th, 09, 11:45 AM Thread Starter
Lars
67 Sinner's Avatar
Re: RS section
yeah, i bought this whole converting-kit, including all the parts. but silly me figured that everything was just bolt-on, not having to pull out the welder. but that just became the next thing on my to-do list.
thanks
Lars
post #5 of 8 (permalink) Old Jan 18th, 09, 02:13 PM
Broc
Re: RS section
Well if you have nice standard fenders to work worth, it may be worthwhile to do the conversion by cutting out the standard mounting brackets and welding in the rs brackets. otherwise finding nice solid gm rs fenders is a good $$ saving route. Not sure what all the kit has and if it uses the factory way of opening or not, but the tricky part is getting the doors to open and close, getting it all too fit is relatively easy.
1968 Camaro SS 350
post #6 of 8 (permalink) Old Jan 18th, 09, 02:45 PM Thread Starter
Lars
67 Sinner's Avatar
Re: RS section
the fenders are so to speak, in mint condition. painted and everything.
i thought of using a piece of the original lamphousing and add the new bracket.
here's a link to the kit i got:
http://http://www.ss396.com/mm5/merchant.mvc?Screen=PROD&Store_Code=camaro6769&Pro duct_Code=RSKIT-8W&Category_Code=RALLYSPORTKITSSUB
i'll check it out the next time i go to the garage. both ways should work out i guess.
thanks!
Lars
post #7 of 8 (permalink) Old Jan 19th, 09, 09:50 AM
Re: RS section
The fender brackets can be bolted in place - no need to weld them.
BPOS is offline
post #8 of 8 (permalink) Old Jan 19th, 09, 11:26 AM Thread Starter
Lars
67 Sinner's Avatar
Re: RS section
yes, i'm about to figure it out i think. i have a thread in the bodyshop about the same issue, and i think i might have gotten the wrong ones when i ordered the kit. the ones i got, only has two threaded holes in them, for the headlight housing, but the ones you mean, has a number of holes in them, right? i got two pairs of the ones on the left, but i believe i should have one pair of each, like the pic.
Lars
