Forum How-to's? - Team Camaro Tech
post #1 of 6 (permalink) Old Jun 20th, 11, 06:36 PM Thread Starter
Matt
Forum How-to's?
Is there a compilation of How-to's for using this forum?
I have tried to figure out how people post pictures where the picture is small until you click or hover over it then it gets bigger. How do you do that?
Also, I try to use the search function as much as possible so I don't ask questions that have already been answered. But when I do I get sooo many responses that it takes forever to read through them all. It appears that if you type "Performer RPM Air Gap Port Size" the search function looks through the entire thread to see if all of these words appear in the tread. I cannot find a way to require that the words appear in the same post or together.
I have also tried using the advanced search and searching the title only. In this case it looks like it returns any thread that has at least one of these words in the title.
I would really appreciate it if someone could point me to so information on how to use the search function and how to post the pictures so they are small until they are clicked on. I did find Christropher's info on posting photos but I didn't see how to do what I want.
Thanks for any help.
Matt
Matt
67 RS, 406 small block, TKO600, Moser 12-bolt (3.73)
MW67RS is offline
post #2 of 6 (permalink) Old Jun 21st, 11, 03:56 AM
Guess
HwyStarJoe's Avatar
Re: Forum How-to's?
I moved you over here Matt...
I agree with you on the site-searches... it needs some tweeks. I'll bring that up to the admin and see if anything can be done to help make the searches more accurate.
HwyStarJoe is offline
post #3 of 6 (permalink) Old Jun 21st, 11, 05:27 AM
Re: Forum How-to's?
Check for pm, HWJ.
capt
Bumper sticker- I'm not SPEEDING
I'm QUALIFYING!
captcanuck68 is offline
post #4 of 6 (permalink) Old Jun 21st, 11, 01:55 PM
Re: Forum How-to's?
OK....
when you post a reply you'll see a Go Advanced button below....click it.
When you get to that box , at the top you'll see a paper clip (click that)
That will open another window where you'll see a browse button (click it) then go through your pictures on your computer and click the one you want (the picture name will appear in the box (click the open button) which will then take you back to the first box where you'll click the upload button.
After the pic uploads you go back to the paper clip, click it and you'll see your pic name there. When you move the mouse over it, it will high lite it....click it. Then in your post you will see [ATTACH]****[/ATTACH] (<--**** will be numbers). Hit the submit reply button. You're done
68 Camaro~LSx ~all motor
post #5 of 6 (permalink) Old Jun 21st, 11, 03:24 PM Thread Starter
Matt
Re: Forum How-to's?
Thanks Doug. I followed your directions and it worked great.
Matt
Matt
MW67RS is offline
post #6 of 6 (permalink) Old Jun 21st, 11, 04:14 PM
Re: Forum How-to's?
No problem
