Problem loading double click ads - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 22nd, 11, 06:47 PM Thread Starter
Matt
I don't know if this is the right place to ask this question but I have started having trouble navigating the forum. When I try to open a thread or a forum it won't load. It says at the bottom waiting for double click ads or something like that. I wait and it never opens so I click the X to stop loading the page and then click refresh. Sometime it works other times it doesn't.
Can anyone recommend what I can try to fix this problem?
Matt
67 RS, 406 small block, TKO600, Moser 12-bolt (3.73)
MW67RS is offline
post #2 of 3 (permalink) Old Sep 22nd, 11, 09:02 PM
69-Pace's Avatar
Re: Problem loading double click ads
If you are using firefox load an add on called no script and only allow the site, and forbid doubleclick and the others and you will get an ad free page.
Or you can enter doubleclick into your blacklist if you use spybot search and destroy's tea timer, or enter "*doubleclick.com" into your hosts file and point it to ip address 0.0.0.0 and it will never be seen again on any website.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 3 (permalink) Old Sep 23rd, 11, 05:24 AM Thread Starter
Matt
Brian,
Thanks for the recommendation. I loaded the no script add on and now I can navigate through the forum much better. Before it would only load a page maybe 20% of the time. I haven't had a problem since I loaded the add on.
Thanks again.
Matt
MW67RS is offline
